Old 08-16-2007, 12:34 PM   #1
jm1681
Janghwa, Hongryeon
jm1681's Avatar
Drives: 20th AE VW GTI
Lightweight batteries anyone?
Anybody have a lightweight battery in their Yaris?
I figure a lightweight drycell in the trunk will help out a bit with weight distribution/reduction quite nicely.
22B | 藤原とうふ店 | Fatal Frame | 呪怨 | 장화,홍련 | Strong Bad
How to survive a Zombie attack
"The inerasable scars, left by the palms of my hands"
365tuners
jm1681 is offline   Reply With Quote
Old 08-16-2007, 12:38 PM   #2
Astroman
Modded Moderator
Astroman's Avatar
I've wanted to get one for track days.
Old 08-16-2007, 12:45 PM   #3
jm1681
Janghwa, Hongryeon
jm1681's Avatar
I figure the motor being a 1.5 shouldn't require mountains of juice to turn over.
Braille's All-season joint (15lbs) should take a fair amount of weight off the car, and putting it in the trunk should help balance things out a bit.
Just wanted to see if anyone had first hand experience with them in the Yaris.
Originally Posted by blueskana View Post
Deka (aka Braile) from Helix13. Though in the stock mounting position.
Noticable change? How much did the stock battery weigh? Any problems starting?
365tuners
Old 08-16-2007, 12:44 PM   #4
blueskana
blueskana's Avatar
Drives: 2007 Yaris LB
blueskana is offline   Reply With Quote
Old 08-16-2007, 01:16 PM   #5
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
03Z33 has an odyssey in the stock location. i think he saved about 20 lbs. i was going to do a relocation but the added weight of 1/0 cable, distribution block, battery mount, etc, would counteract the weight loss of a lightweight battery.
i think a race battery in the stock location is the best solution.
reznunt is offline   Reply With Quote
Old 08-16-2007, 01:30 PM   #6
jm1681
Janghwa, Hongryeon
jm1681's Avatar
I see your point.
Still, moving a large mass to the rear, and alleviating the front end altogether doesn't seem like a bad proposition.
365tuners
Old 08-16-2007, 03:13 PM   #7
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
Originally Posted by jm1681 View Post
I see your point.
true, if what you're after is weight distribution. even then, you are moving only 13 lbs (lightweight battery weight) to the rear and distributing the added weight of the cables over the length of the car. this would make more sense if you are moving a stock battery (33 lbs iirc?) from front to rear.
if it is weight savings you want, then just replacing the battery with a race battery is the way to go imo.
Old 08-16-2007, 03:37 PM   #8
jm1681
Janghwa, Hongryeon
jm1681's Avatar
To each his own I suppose :)
I'm all for adding lightness, and balance in whatever quantities I can. If that means removing 30lbs from the front of the car, adding 15lbs to the back, and maybe 1-2lbs over the length of the car, that works for me ;)
Factoring in the weight of the cables is glaringly good point I never thought of in nearly 7 years of modding cars
365tuners
Old 08-16-2007, 07:58 PM   #9
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
if you use 1/0 welding cable as your power line, 10 feet of it is going to weigh more than two lbs i think. but if you do the relocation, post pics! i did one in my prerunner but opted not to in the yaris. good luck!
Old 08-16-2007, 03:56 PM   #10
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
What do y'all think about Optima batteries. They claim to be light weight.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 08-16-2007, 03:58 PM   #11
jm1681
Janghwa, Hongryeon
jm1681's Avatar
I always though Optimas were basically just spillproof.
Didn't think they had specific ranges of light batteries
365tuners
Old 08-16-2007, 04:04 PM   #12
YarisTom73
46 and 2, just ahead...
YarisTom73's Avatar
Drives: 07 Yaris sedan
Lightweight? No way! Quite heavy. The only advantage to these batteries is their resistance to spilling (gel contents), vibration resistance (spiral core), and of course the ability to use inside the cabin, as they have no breathable emissions. It is a totally sealed unit. So, the offroad 4x4 guys and the racing guys love these. As far as lightweight, never heard that quality.
I suppose we could just get a hand-crank like in the roaring 20's
YarisTom73 is offline   Reply With Quote
Old 08-16-2007, 04:13 PM   #13
jm1681
Janghwa, Hongryeon
jm1681's Avatar
^ Theres an idea :D
365tuners
Old 08-16-2007, 04:15 PM   #14
nsmitchell
nsmitchell's Avatar
This is the lightest battery I could find...
http://hilaroad.com/camp/projects/le...n_battery.html
Get YarAss in gear!
RIP - Casey Tatum
Old 08-16-2007, 04:29 PM   #15
jm1681
Janghwa, Hongryeon
jm1681's Avatar
Might come up short in the CCA department. Nevertheless that'll knock some weight off :D
365tuners
Old 08-16-2007, 08:47 PM   #16
mandriu
11b1p
mandriu's Avatar
Drives: yaris s
does any think a goldwing battery would work. The engines bigger but battery must be smaller.
mandriu is offline   Reply With Quote
Old 08-17-2007, 12:50 AM   #17
oh hell i actually clicked on that... doh!
lightweight flywheel from fidanza dngz Performance Modifications 34 02-03-2009 11:02 PM
dual batteries or use a cap? punch In Car Entertainment + Electronics (audio / video / alarm) 14 07-17-2007 03:19 AM
anyone know the benifits of lightweight wheels? BrazdonW Wheels, Tires and Suspension Forum sponsored by The Tire Rack 59 07-16-2007 08:22 PM
ZPI Racing Toyota Yaris 06-07 Lightweight Crank Pulley SebYRS Items for Sale by private party 7 06-19-2007 08:00 PM
Toyota plans hybrid that runs on batteries hhcchen Off-topic / Other Cars / Everything else Discussions 2 07-22-2006 01:35 AM
