Old 09-17-2007, 10:21 AM   #1
jlift
Drives: 2007 Yaris Hatch
P0456 OBD code?
my Scangauge just caught a P0456 engine code.
Seems to be evaporative canister, fuel line related. Anyone have this code? If so, what did they do or tell you when they fixed it? It is harmful to drive with it? Had to drive to work today, 60 miles round trip, but am taking it in tonight.
Thanks.
jlift is offline   Reply With Quote
Old 09-17-2007, 10:58 AM   #2
steved
Yaris Rules!!
Drives: 2007 Red Yaris Liftback a/t
Is your gas cap on tight? It is the most common problem.
The Yaris goes into self diagnostic mode on the Evap system after the car has been shut off for a certain time. If it finds a leak somewhere in the system you will get the P0456 code also.
The secret of life is honesty and fair dealing. If you can fake that, you've got it made.
Groucho Marx (1890-1977)
steved is offline   Reply With Quote
Old 09-19-2007, 11:16 AM   #3
jlift
Well, just got back from the dealer's and here is the resolution of the P0456 Code: (Quoting from finished repair order)
"Customer states that check engine light is on - check & advise. Cause: Code P0456 Evaporative system leak detected. Very small leak...
Correction: Perform Evap. system check. Perform smoke leak test in evap. system. No leaks found. Reset engine light. Run monitor. No codes found after check out."
They told me that I might not have put the gas cap on correct, but I know I did. Does everyone who has a Yaris notice that the gas cap will only click closed one or two clicks?
What exactly is a "smoke leak tes"??
Old 09-19-2007, 02:02 PM   #4
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
gas cap is one click. they use a smoke machine to visually check for leaks.
you can buy one here if you want lol: clicky
reznunt is offline   Reply With Quote
Old 09-19-2007, 02:12 PM   #5
jlift
Yeah. I'm getting one! They should be part of every car owner's set of tools. Such a deal!
Old 09-19-2007, 03:18 PM   #6
YamilR
YamilR's Avatar
do I sense sarcasm?
Old 09-19-2007, 03:28 PM   #7
jlift
Wink
Your sensors are in proper working order. I thought that the link provided was for a gas cap! Besides, sarcasm makes the world go round.
9/29 HIN Night Shaft Coupon Code JosephDoc California 7 09-30-2007 08:36 PM
2007 Yaris and OBD II kaboom DIY / Maintenance / Service 6 05-05-2007 03:48 PM
Blazing Blue Metallic Paint Code? R0ME0 General Yaris / Vitz Discussion 3 03-27-2007 08:18 PM
Whats our Chassis Code? Treyz General Yaris / Vitz Discussion 9 01-25-2007 03:04 PM
Anybody know the code? Driver New YARIS Purchase Forum 5 08-20-2006 06:56 PM
