Old 05-04-2007, 09:06 AM   #1
kaboom
kaboom's Avatar
Drives: 2007 silver yaris sedan
2007 Yaris and OBD II
Is '07 Yaris OBD II compatible? I use KAL EQUIP reader on both : my '03 Corolla and daughter's '02 Mazda Protege, and it reads the codes perfectly. Yesterday I hooked it up to my new Yaris, just to check if it works and guess what ....the scanner would repeatedly throw "reading error" message. I tried w/ ignition on and engine on, and w/ignition on and engine off...same result.Any suggestions/opinions ?
kaboom
kaboom is offline   Reply With Quote
Old 05-04-2007, 10:42 AM   #2
ChinoCharles
Drives: LB
Don't scanners need to be flashed with information pertinent to newer model year cars? Maybe you just need a software upgrade?
Old 05-04-2007, 12:59 PM   #3
kaboom
kaboom's Avatar
thanks, charles - I will try to get info on software upgrade ( to CAN ?) on my KAL EQUIP reader
kd
Old 05-04-2007, 08:45 PM   #4
ToyotaTEch21
Drives: 2007 Yaris Sedan
Yes it just needs to be compatible with can, most scanners you buy now will be can compatible. Check for an upgrade if you cant, just look for one of the $60 ones just check the package for can.
ToyotaTEch21 is offline   Reply With Quote
Old 05-05-2007, 01:11 AM   #5
joey1320
joey1320's Avatar
Drives: Yaris LB
it has to be obd2 compatible, is the law.
most definitely your scanner is outdated as stated above.
good luck with the upgrade!
Old 05-05-2007, 03:38 AM   #6
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
As stated before your car should and has the OBD II. Its the law and I believe cars made from 1995 and up have it. Of course there are some exceptions before that time. But all cars or most in the U.S. should have them.
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 05-05-2007, 03:48 PM   #7
ToyotaTEch21
Close 96 and up
