Old 04-15-2010, 06:37 PM   #1
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
Lexus IS250 gas pedal + Lexus IS Sport Pedals/deadpedal
I wasn't really a fan of the OBX pedals offered and after talking with an MR2 owner about aftermarket pedals they told me that I look into going with the IS Sport pedals since it's a very common modification to do to other Toyotas and fairly simple.
After realizing that no one had in the Yaris community I figured why the heck not!
Simple for others doesn't translate to simple for us unfortunately. Because the USDM Yaris has a nasty plastic blocky shaft as a pedal with no pin holding the pedal in place as it's molded to the plastic, I had to find a replacement pedal. Which is where the IS250 pedal comes into play.
The sensor plug is identical and the pedal can just be plugged in without any modification. However the mounting holes on the pedal assembly are reversed on the IS pedal, which requires you to open the pedal assembly and transplant the inards to the Yaris pedal.
Unfortunately the angle of the pedal shaft is totally wrong and you wouldn't get more than 20% in to the pedal travel before it hits the carpet, so you have to do some bending to the shaft to make it work.
Definitely makes the cabin look sportier. I still need to make some minor adjustments to the pedal, since it's angled back more than I would like, but otherwise feels very nice.
Old 04-15-2010, 06:52 PM   #2
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
Pretty!
aca72 is offline   Reply With Quote
Old 04-15-2010, 07:01 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
Great!
Old 04-15-2010, 07:13 PM   #4
Black Yaris
der Zeck
Black Yaris's Avatar
how much did this cost you? and are these same pedals available for an Auto?
Old 04-15-2010, 07:48 PM   #5
Gideon
★weeaboo★
Gideon's Avatar
It was around $60 for the two pedal covers (clutch and brake) and the accelerator pedal. The IS250 pedal assembly was $60 from a local junkyard and the dead pedal I got off of flea-bay for $25.
The part numbers are 78101-20150 for the gas pedal (which requires a pedal assembly where the pedal is attached to the shaft via a pin) and for the manual transmission it's 31321-53010 for the brake and clutch, it's only for one, so you'll need to order two, one for each. For automatic transmission the part number is 47121-53010 I believe, but you may need to double check with a dealer to verify. No idea on the IS250 pedal assembly or the deadpedal part numbers though.
I just got the direct oem replacement just slips right over like a glove.
Yeah, I noticed those as well, but IMO they look way too cheap. Anywho this actually also changes how close the gas pedal is to the brake, so heel toe is easier.
Old 04-15-2010, 07:30 PM   #6
YarisSedan
Drives: 08 Yaris Sedan
Old 04-15-2010, 07:51 PM   #7
Black Yaris
der Zeck
I have throttle by cable on the RAV, so I can not use the pedal assembly... but I can use the pads
Old 04-15-2010, 07:59 PM   #8
Gideon
★weeaboo★
Gideon's Avatar
Right, you can use all the pads probably. That's what the MR2 owner (now I forget his name oh well) was saying was that the pedals are all the same size and even if it's DBW or cable, so long as the pedal shaft uses a pin to secure the pedal to the shaft it'll work, which is why it's such a common mod.
Of course, not so for us in Yaris land, but nothing a blowtorch and a hammer can't fix.
Old 11-25-2016, 08:23 AM   #9
ACKING_QC
Drives: 2018 VW TSi Stage1
thread bumping because of reasons ! I'm at school will do a search later LOL
ACKING_QC is offline   Reply With Quote
Old 05-04-2017, 08:43 PM   #10
ACKING_QC
what about that custom cluster you have there ?? I want more info on that !!
Old 06-07-2017, 04:33 PM   #11
ABSPLASTIC
Drives: Twin-charged rotary V8 w/nos
Follow up with creepin:
http://www.yarisworld.com/forums/showthread.php?t=54688
ABSPLASTIC is offline   Reply With Quote
Old 05-05-2017, 08:49 PM   #12
SirDigby
Drives: 2007 yaris 3 door
it's not custom, it's a TRD part. i don't know the number. i haven't found a good source for them yet. i come across used ones once in a wile, but they are like +$600...
Old 05-06-2017, 08:54 PM   #13
ACKING_QC
Gaaaawd DAMN
Old 09-25-2022, 10:38 PM   #14
remcafee
has anyone else done this? so all you did was swap out the electronic throttle components over to lexus pedal and then had tobend the shaft a bit? did yoy verify youre getting 100% throttle?
Old 09-26-2022, 01:46 AM   #15
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
I have, except I bought the NCP131 Vitz RS pedal bracket from Amayama so I didn't have to bend my pedal arm. Bolted straight in like factory. Not sure if it works in the 2nd gens though.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 10-04-2022, 02:50 AM   #16
remcafee
you mind getting some pics for me? i wanna compare the 2nd gen pedal shaping, i might get a 3rd gen pedal
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
Gas pedal problem? Befuddled Performance Modifications 28 01-27-2010 09:55 AM
WTB: Gas Pedal ASsembly... Nexus1155 Items for Sale by private party 0 09-16-2007 09:29 PM
Gas pedal fmicle DIY / Maintenance / Service 12 03-31-2007 12:08 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
