![]() Drives: 2007 yaris Join Date: Jul 2020
2006 Yaris head gasket replacement?
Hello All
Just wanted to ask if any one has had long term success after replacing a head gasket on a 2006 Yaris as the thermostat froze in the closed position and severely overheated the engine The reason I ask is I was told by a toyota repair shop that they do not do head gasket replacements on the Yaris engine I vaguely remember hearing due to a poor long term success rate with this repair. Also, not really sure who to go to for a precision cyl. head resurfacing job as it's been years since I've indulged in this sort of thing and most machine shops back then mostly worked on domestic iron. So I have a few questions. #1) do most just go ahead and get a replacement engine from one of these import engine suppliers? prices seem to range between 600.00 and 800.00 around here. #2 Is using an after market head gasket as good if not better than an OEM gasket? #3) Do these engines use torque to yield head bolts or can the old ones be reused? #4) and finally since the engine block is also aluminum do they ever warp just like the cylinder head? Any and all comments are greatly appreciated. The car is a daily driver and runs perfectly but coolant needs topping off every couple days |
I'd go used engine, some good yards will give you a warranty for them.
#2 yes, most shops use aftermarket gaskets. #3 yes, most engines since the 90s have those head bolts. #4 most shops have the head only machined flat. |
| head gasket replacement Oh7yaris | RebarLoko416 | DIY / Maintenance / Service | 6 | 01-21-2019 12:23 PM |
| Head gasket | thefalls | Forced Induction Forum | 12 | 11-12-2012 12:26 AM |
| 2006 Yaris Hatchback Replacing Stereo Head Unit help | lauren24 | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 07-01-2010 11:13 PM |
