Old 01-19-2019, 05:20 PM   #1
RebarLoko416
Drives: oh7 midnightblu
Post head gasket replacement Oh7yaris
is it even necessary to remove the knock sensor for this project??? And should I replace timing chain. anything y'all can help me out here with would be well received. I've removed:
valve cover
intake manifold
exhaust manifold(mid-post){removing mani from pipe now
and all other little associated sh@*! that goes in the process of getting to this point.
finishing mani/pipe now.... thx RL416
RebarLoko416 is offline   Reply With Quote
Old 01-19-2019, 05:48 PM   #2
RebarLoko416
exh mani extracated,
necessary to remove timing chain cover??
Old 01-19-2019, 06:04 PM   #3
RebarLoko416
anyone out there interested in popping my forum cherry???
Old 01-19-2019, 07:02 PM   #4
When I did this job on my wife's '02 echo (just for kicks) I removed the timing cover but had enough room to keep the engine in the engine bay.
The repair manual calls for removal of the timing cover and I honestly dont know if you can get away with doing it with the cover still assembled. I would just remove it. I'd leave the timing chain unless you had specific issues with it, those things last forever in these engines.
Knock sensor sits on the block so it doesnt gerd to he touched. Make sure you have a manual showing you how to reset the timing and where to place the rtv when reassembling.
Old 01-20-2019, 04:47 PM   #5
RebarLoko416
tmontague: Thanks for getting back to me sir. I’m currently trying to get a service manual, I came across a thread that had two links to no avail, and another that says go to the last page in the forum???
Old 01-20-2019, 06:58 PM   #6
I have the pdf on my google drive, but I dont think I can email you the full thing and I'm not the most IT literate person.
A Haynes manual will also work well. I believe there is a website that for $20 will give you full downloadable version of the factory repair manuals, I just cant remember the name off the top of my head
Old 01-21-2019, 12:23 PM   #7
thetut
Drives: 2007 4dr sedan
Try this site: https://cardiagn.com/1nz-fe-engine-m...cylinder-head/
thetut is offline   Reply With Quote
Head gasket location and part vidfan General Yaris / Vitz Discussion 5 11-17-2016 12:57 AM
Front Exhaust Gasket Replacement tmontague DIY / Maintenance / Service 6 03-25-2015 10:00 PM
Head gasket thefalls Forced Induction Forum 12 11-12-2012 12:26 AM
