Old 12-08-2008, 01:21 AM   #1
tkevin07
Drives: Yaris Hatchback
9003 Harness
So does anyone know which pin is the ground, the one for high and the one for low?
also when high beams are on, does the low beams stay on also?
thanks!
tkevin07 is offline   Reply With Quote
Old 12-08-2008, 01:22 AM   #2
tkevin07
Smile
Old 12-08-2008, 03:19 AM   #3
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Im on my phone and trying to make a harness diagram with text so bare with me.
| _ |
This is the harness assuming that youre looking at it with the middle pin at the bottom.
Red = ground
Blue = low beam
Green = high beam
I had to find this out when installing my HIDs because it had no high beams and had only 2 pins to connect to the harness.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 12-08-2008, 11:16 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
i belive the yaris uses separate grounds and a common positive.
Old 12-09-2008, 12:10 AM   #5
tkevin07
it should be one common ground and two positives, does the low beam have power when the high beams are on? need to rewire a HID kit, telescopic =D
Old 12-09-2008, 03:24 AM   #6
eii
Rides canyon walls
eii's Avatar
yeah thats right my bad. ground in diagram is actually a common positive.
Old 12-09-2008, 10:10 AM   #7
IllusionX
The yaris uses constant positive everywhere.. and a switched ground. You can basically tap into any wires in the car if you are lazy to add a fuse for whatever you are doing. And then use the ground point of your choice....
Old 12-09-2008, 12:11 AM   #8
tkevin07
i think its stupid how its one bulb for the highs and low, if it goes out then you dont have a backup on that side
Old 12-09-2008, 12:12 AM   #9
tkevin07
thanks a lot for the diargram and help also!
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 03:12 PM
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
F.S. MOMO Acropolis Evo Carbon Kevlar Competition Seat with 4 piont Harness Ric n Sov's Vitz RS Items for Sale by private party 2 10-19-2008 02:34 AM
Headlights harness slvryaris Cosmetic Modifications (Exterior/Interior) 13 07-19-2007 01:19 AM
How exactly does an heavier duty harness work? IsLNdbOi Performance Modifications 5 09-26-2006 05:19 AM
