Old 12-19-2008, 01:11 PM   #1
09TRD
Drives: 09 Yaris hatch, 09 Z51 'Vette
Seeking wheel advice from someone who KNOWS
I'm looking at Centerlines (forged 6061-T6 alloy). They weigh 14 pounds each and are a bargain.
http://centerlinewheels.com/wheel_de...ehicle&data=33
Anyway, I want a 15" wheel. The size they're offering is a 15" X 7" with a +42 mm offset.
I plan on running a 205/55-15 tire and have the full TRD suspension on the car (springs, shocks, bar).
Is that combination going to give me the clearance I need? I want NO RUBBING AT ALL.
Also, what is the hub diameter for these cars? I've heard 54.1". Is that correct?
I also wanted to verify that the lug spacing is 4 - 100mm.
09TRD is offline
Old 12-19-2008, 01:15 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
you are correct on all counts.. try to pick a "narrow" 205/55.. the fuzion zri was a pretty narrow 205 IIRC
Tamago is offline
Old 12-19-2008, 01:19 PM   #3
09TRD
Will a "wider" 205/55 rub with that wheel?
09TRD is offline
Old 12-19-2008, 01:22 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
read up on section widths and tread widths on tirerack.com
i think you should clear a +42 ok with no rubbing issues.. what tire were you looking to get?
Tamago is offline
Old 12-19-2008, 01:15 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
curious.. what is a "steal" because that's a pretty heavy 15" wheel
Tamago is offline
Old 12-19-2008, 01:17 PM   #6
09TRD
I don't know what you mean when you ask, "What is a steal?"
14 pounds is incredibly light for a 15" X 7" wheel.
Most cast aluminum wheels in that size weigh between 18 and 19 pounds and aren't as strong.
09TRD is offline
Old 12-19-2008, 01:20 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
12lbs is about average for a 15x7 "light" 15x7
a LIGHT 15x7 weighs under 10lbs
http://edgeracing.com/wheel/7866/
Tamago is offline
Old 12-19-2008, 01:22 PM   #8
09TRD
How many ten pound wheels do you see here?
http://www.tirerack.com/wheels/resul...ar=&sort=Brand
19 pounds is about average for the TYPICAL 15 X 6.5" - 15" X 7" gravity cast aluminum wheel.
Racing wheels tend to bend on bad pavement (e.g. potholes, which our roads are full of). I don't want that. I want a robust wheel that's designed to handle the realities of STREET use.
Oh, I'm 45 and have a degree in mechanical engineering.
Go anything else you want to ask?
09TRD is offline
Old 12-19-2008, 01:25 PM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
19 pounds is about average for the TYPICAL gravity cast 15" X 7":
you're looking in the wrong places then..
www.goodwinracing.com will point you in the direction of quality wheels..
Tamago is offline
Old 12-19-2008, 01:31 PM   #10
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
I have sub 10lb wheels on our Yaris.
Enkei RPF1s are sub 10lbs if you don't want to spend big $$ on wheels.
a 19lb 15" wheel is insane, i've had 17x8s that were that light.
Russelt3hPirate is offline
Old 12-19-2008, 01:22 PM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
i mean, how much are you getting them for?
Tamago is offline
Old 12-19-2008, 01:30 PM   #12
09TRD
Call and ask:
I believe they're in the $150 (each) range, which is extremely competitive for a forged 6061-T6 alloy wheel.
09TRD is offline
Old 12-19-2008, 01:31 PM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
Call and ask:
for forged, absolutely..
but for forged it's on the WAY heavy side
Tamago is offline
Old 12-19-2008, 01:51 PM   #14
Tamago
Tamago's Avatar
Drives: UZJ100
then how come it says:
This 15-inch forged wheel weighs only 14 lbs and is stronger than a cast wheel ! ++
Tamago is offline
Old 12-19-2008, 01:56 PM   #15
09TRD
14 pounds is light for an aluminum STREET wheel with a 1,200 pound load rating.
Racing wheels can be lighter because tracks aren't full of potholes, frostheaves and expansion joints.
Drive a 10 pound racing wheel on these roads and see how long it lasts.
http://www.6speedonline.com/forums/w...treet-use.html
"A word on BBS Race wheels for street use
I see many inquiries and threads on these wheels, and I think it's fair to warn people that don't know that these wheels were not designed for street use and BBS does not recommend them to be used off of a track. The barrel sections are roll formed and they are considerably thinner on these wheels than they would be on one of their road wheels. It saves weight, but it makes the wheel much more likely to be damaged by potholes, etc."
09TRD is offline
Old 12-19-2008, 02:03 PM   #16
Russelt3hPirate
l33t3st Asshole
so bc a specific BBS "race" wheel isn't meant for street use all light weight wheels don't pass your strict testing?
Old 12-19-2008, 02:05 PM   #17
Tamago
Tamago's Avatar
Drives: UZJ100
i think this guy should change his thread title to "seeking advice from people who will agree with me"
because you're talking right now to two people who KNOW
Tamago is offline
Old 12-19-2008, 02:20 PM   #18
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
14 pounds isn't "obscenely heavy" for a 15x7, but it's not exactly "light", either.
My 15x7 Falken Hanabi's weigh just a tick over 11 pounds each and cost about $89 each. THAT is light and cheap. But, not everyone likes the styling. My goals were "light and cheap", so I didn't care.
To answer your rubbing question: I'd stick with 195/55's. I've not had any rubbing with those. Had some with 215/50's (Toyo T1-R, which were actually closer to 205). And I'm on 15x7 with 41mm offset.
I also had rubbing on the upper fender liner under hard cornering with 195/55's on a 15x7 with 32mm offset. Definitely stick with offset in the 40-45mm range unless you value the bling of "flushness" more than not rubbing.
Loren is offline
Slightly damaged wheel aucorium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 12-06-2008 07:06 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
Wheel Advice caveatipse Cosmetic Modifications (Exterior/Interior) 8 09-19-2007 02:39 AM
Yaris wheel rate ratio (06+) ? dsc_pat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 07-05-2007 05:43 PM
