Old 12-03-2008, 12:20 AM   #1
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
Slightly damaged wheel
HEy Guys
quick Question
i was driving to work yesterday ,and they had been working on the road at night but didnt put up any beacons , so they had removed tar for about 500m , as i couldnt go anywhere else i had to ride this section of road , i ended up riding over the part where they had stopped working and it left a ledge ,and buckled my left front wheel , luckly the tire is ok .
i had the wheel repaired , wheel alignment and balancing done , they say everything looks ok , i had a look at the front shocks and all seems ok , anything i should look out for ??? maybe hidden damage i dont know??
thanks guys.
PS: Tenzo R wheels are pretty hard , my wheel didnt even crack.Michelin make great tires aswell , the tire was still 100% , no damage.
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 12-04-2008, 12:04 AM   #2
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
any opinions?
JDMtuner
www.jdmtuner.co.za
Old 12-04-2008, 02:47 AM   #3
DuckinOut
QUACK~!!!!!
DuckinOut's Avatar
Drives: Yaris LB
Send a message via AIM to DuckinOut
car suspension can take a harder beating then just what you put the car thru ... i don't think you really have to worry about anything else other then aligment
if you have coilovers and are still under warranty, you can try and send them back and have them check out your suspension if it's blown or if there is anything else wrong with the coilovers
" ... I don't follow, thus i reign SUPREME . The only time i follow is when i follow my dreams ... "
DuckinOut is offline   Reply With Quote
Old 12-04-2008, 06:58 AM   #4
jclo3313
jclo3313's Avatar
There are wheel fix places all over.( at least in the States) Depending on the damage and how much you paid per wheel this might be the way to go. If you did not spend a ton of money on the wheels just replace the bent one. Tires are very forgiving and you should not have any worries there. Line it up and fix your wheel and have some fun.
Obama Can't Gymkhana!
Old 12-04-2008, 05:53 PM   #5
ddongbap
Lol. "In the states." Doesn't help Mr. South Africa over there.
Old 12-06-2008, 07:06 AM   #6
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
thanks guys , yeah , i had the wheel fixed , cost me R700.00 ZAR , a new wheel would have been R3000.00 ZAR , so just keeping an eye on it to see if there are any leaks etc.
JDMtuner
www.jdmtuner.co.za
xA steering wheel bzinn 1 Cosmetic Modifications (Exterior/Interior) 17 11-09-2008 04:14 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
Yaris wheel rate ratio (06+) ? dsc_pat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 07-05-2007 05:43 PM
Slightly Bent Steel Wheel, what should I do? mgthompson Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 02-06-2007 10:38 PM
