Old 02-15-2009, 04:54 PM   #1
Meteorite_Marty
Toyota Premium Horn
I am thinking of upgrading my stock horn and getting rid of the "meep meep" road runner sound, so other drivers will actually hear my horn and take it seriously. :)
Does anyone have experience with installing these particular Toyota Premium Horn kit? Since there is only one stock horn, can the wiring be split to run to 2 horns instead? Is there perhaps another set of wires to use a second horn? I would like to keep everything Toyota plug and play, I am wondering what my options are to getting the exact plastic connector ends to fit into the horns directly.
I am unsure what the official instructions say, since they are in Japanese. This looks like it assume there are 2 horns on the car already.
Any advice? Please and thank you!
Old 02-15-2009, 05:45 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Hi Marty
if you look behind your grill you should see the orginal horn ,
Taped to it should be another set of wires to plug in a second
horn .
Old 02-15-2009, 06:51 PM   #3
Meteorite_Marty
Right on! I knew you would know something about this.
Did you happen to use this horn?
Old 02-15-2009, 07:35 PM   #4
Meteorite_Marty
Can anyone buy/ship these inexpensively? I see them online for aobut $70, then shipping to be added.
Old 02-15-2009, 07:37 PM   #5
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
I'm getting my doubts that's a genuine Toyota product, typically the silver holographic seal is pretty obvious...
Old 02-15-2009, 07:51 PM   #6
POORSHA
POORSHA's Avatar
Drives: 2008 LB
I just put 2 wolo horn in my 2008 lb i did not see an additional wire taped to the origianal wire. i made a wire to split the feed.
POORSHA is offline   Reply With Quote
Old 02-15-2009, 11:03 PM   #7
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
MADDOG has a thread here on here somewhere,
the Toyota ones are the same just rebranded
Old 02-16-2009, 12:53 PM   #8
Danish Yaris
Drives: Toyota Yaris 1,8 TS 5dr. 2007
Hi
Do you have a part number for these horns?
Regards Steven.
Danish Yaris is offline   Reply With Quote
Old 02-16-2009, 12:54 PM   #9
Meteorite_Marty
Hi Marty
horn .
I had a look, and unfortunately there are no other wires taped to this area that look like they are for the horn. There is a thick collection of pink and white wires, but no green wire or connector for a horn.
Old 02-16-2009, 12:57 PM   #10
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
Originally Posted by Danish Yaris View Post
Hi
Regards Steven.
x2
Old 02-16-2009, 01:04 PM   #11
Meteorite_Marty
Hi
Regards Steven.
I am not sure of the part number.
Old 02-16-2009, 01:06 PM   #12
Meteorite_Marty
If you splice the existing wire, do you have to worry about blowing a fuse when adding the 2-tone horn system?
Old 02-16-2009, 01:26 PM   #13
Yaribhini
Drives: Yaris
My guess is that you will need to have it wired separately as horns take some juice.
Yaribhini is offline   Reply With Quote
Old 02-16-2009, 04:50 PM   #14
Benggolf2
Benggolf2's Avatar
Meteorite_Marty, I know you like to keep all mods to Toyota/OEM parts, but really you should look into Fiamm El Grande electric horns.
I have a set on my car they they are fantastic! It's now on sale for $19.94 at Amazon.com! .
Benggolf2
Old 02-16-2009, 05:10 PM   #15
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
My mistake sorry, i was looking at my Station Wagon , Ooopp's
if you install these or something similar you will have to increase fuse size
to at least 15 amp .
Old 02-16-2009, 09:18 PM   #16
Meteorite_Marty
I assume that is not as simple as just popping in a higher amp fuse? Won't the wiring burn in such cases?
Old 02-16-2009, 09:19 PM   #17
Meteorite_Marty
Thanks for the suggestion... did you have to do any wiring alteration? How were you able to integrate the Fiamms into the existing wiring. Any problems with fuses blowing?
Old 02-16-2009, 09:54 PM   #18
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
here guy's check this thread out
http://www.yarisworld.com/forums/sho...highlight=horn
should answer a lot of questions
Genuine Toyota Hitch for Yaris now available in Canada voodoo22 DIY / Maintenance / Service 8 04-22-2014 07:50 AM
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 08:59 PM
Response from Toyota Driver New YARIS Purchase Forum 22 09-04-2006 07:44 PM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 03:16 AM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
