![]() ![]() ![]() Drives: 2008 5-door Yaris Hatchback Join Date: Oct 2008
Toyota Premium Horn
I am thinking of upgrading my stock horn and getting rid of the "meep meep" road runner sound, so other drivers will actually hear my horn and take it seriously. :)
Does anyone have experience with installing these particular Toyota Premium Horn kit? Since there is only one stock horn, can the wiring be split to run to 2 horns instead? Is there perhaps another set of wires to use a second horn? I would like to keep everything Toyota plug and play, I am wondering what my options are to getting the exact plastic connector ends to fit into the horns directly. I am unsure what the official instructions say, since they are in Japanese. This looks like it assume there are 2 horns on the car already. Any advice? Please and thank you! |
Hi Marty
if you look behind your grill you should see the orginal horn , Taped to it should be another set of wires to plug in a second horn . |
Right on! I knew you would know something about this.
Did you happen to use this horn? |
Can anyone buy/ship these inexpensively? I see them online for aobut $70, then shipping to be added.
School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
I'm getting my doubts that's a genuine Toyota product, typically the silver holographic seal is pretty obvious...
I just put 2 wolo horn in my 2008 lb i did not see an additional wire taped to the origianal wire. i made a wire to split the feed.
#7 | |
the Toyota ones are the same just rebranded |
![]() ![]() ![]() Drives: Toyota Yaris 1,8 TS 5dr. 2007 Join Date: Dec 2008
Hi
Do you have a part number for these horns? Regards Steven. |
I had a look, and unfortunately there are no other wires taped to this area that look like they are for the horn. There is a thick collection of pink and white wires, but no green wire or connector for a horn.
If you splice the existing wire, do you have to worry about blowing a fuse when adding the 2-tone horn system?
Drives: Yaris Join Date: Jan 2009
![]() ![]() ![]() ![]() Drives: 2008 Yaris RS 4-Door LB Join Date: Oct 2008
Meteorite_Marty, I know you like to keep all mods to Toyota/OEM parts, but really you should look into Fiamm El Grande electric horns.
I have a set on my car they they are fantastic! It's now on sale for $19.94 at Amazon.com!
Benggolf2 |
#15 | |
![]() if you install these or something similar you will have to increase fuse size to at least 15 amp . |
I assume that is not as simple as just popping in a higher amp fuse? Won't the wiring burn in such cases?
Thanks for the suggestion... did you have to do any wiring alteration? How were you able to integrate the Fiamms into the existing wiring. Any problems with fuses blowing?
here guy's check this thread out
http://www.yarisworld.com/forums/sho...highlight=horn should answer a lot of questions |
| Genuine Toyota Hitch for Yaris now available in Canada | voodoo22 | DIY / Maintenance / Service | 8 | 04-22-2014 07:50 AM |
| Response from Toyota on my special order | drdavidr4u | New YARIS Purchase Forum | 14 | 04-27-2010 08:59 PM |
| Response from Toyota | Driver | New YARIS Purchase Forum | 22 | 09-04-2006 07:44 PM |
| Toyota Delays | Buckethead | General Yaris / Vitz Discussion | 3 | 08-26-2006 03:16 AM |
| Toyota Yaris to Sponsor FOX's "Prison Break" | YarisBueller | General Yaris / Vitz Discussion | 0 | 04-30-2006 08:01 PM |
