Old 11-17-2009, 10:55 PM   #1
WolfWings
WolfWings's Avatar
Cruise Control Transplant 2009->2007 LB
Okay... everything swapped over aside from needing to cut a hole for the stalk. This is a factory cruise-control stalk on a USDM Liftback Yaris, sticks out on the lower-right towards the center console.
Is there two different spiral cable models? I'm asking as my socket had three pins and I swapped the ground/stalk cable from the 2009 model as well but I didn't have the tools or patience to unbolt the steering wheel and verify that.
Also, swapped the clutch bolt over, but no wire to plug that into. What pins on where do I need to route that switch to? And what's the connector part number, if it's available as a seperate part?
2007 lb, 2009 lb, cruise control
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 10:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 07:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 04:55 PM
Retro fit Cruise Control into a 2009 Yaris hatchback 42ezra Performance Modifications 1 05-03-2009 12:04 AM
