![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
HELP...I'm changing the springs/shocks...where to jack up?
I'm going to be getting to this long awaited project and I'm curious where the best place is to jack up on the front and rear ends when doing each side. Also, on all of the DIY guides, I don't see anything about how to get the rear shocks off...is it just held on by the two bolts in the hatch area where you pop the plastic top off?
One other question is when using the box wrench to get the top off of the front struts, do I take those all the way off or will the spring fly underneath? I know it's kind of a dumb question but want to cover all of my bases. I'd imagine you have to take the bolts off of that top hat area under the hood so you can actually get the strut top hat off, but just not sure. |
http://www.yarisworld.com/forums/sea...earchid=550728
and i'd recommend removing your wiper tray to access the top bolts. the top bolts only hold the struts in place. there's another bolt underneath that holds the spring perch on. an impact gun will make your life SO much easier if you have access to one.
the link you gave me has no results found.
thanks for the heads up on the bolts, i feel better knowing the spring isn;t going to fly off and damage me by undoing the top hat bolts in the engine bay. |
use standard jack points.
One other question I have is since I'm using Tokico shocks with this spring install, there's no need to cut the bumpstop right? From my understanding, I would need to cut it if I was using the stock shocks/struts but since I'm not using those and I'm using the Tokicos, there would be no need to.
Really, come on now...I can use the help.
did the aftermarket struts come with their own bump stops?
no they didn't. i'm guessing i'm supposed to use the factory stops, but i'm thinking not supposed to cut them since the new tokicos are stiffer, so no need to cut in the first place.
#9 | |
if you're lowering 2" cut off 2" of bumpstop.
so if the shock is stiffer, then what would be the sense of cutting the bumpstop? It's kind of contradicting to cut something that stops travel of the shock, yet the shock it's on is stiff enough that it wouldn't need to be done. I'm just trying to understand is all.
#11 | |
the spring does. if your spring drops the car 2" you'd want to remove 2" of bumpstop so you don't bounce off the bumpstop itself except for extreme conditions. this allows your new stiffer shocks to actually do their job.
I heard if you buy the TRD springs/shocks
you don't need to cut the bumpstops.....
Never take eyes off opponent - Bruce Lee |
Where is Oahu?
#14 | |
is it THAT big of a deal?
#15 | |
For warranty purposes , yes it is , Toyota does not recomend cutting bump stops with it's TRD products . But other after market shocks and spring set ups it may require this to be done , as you stated best preformance/handling from them. ![]()
#16 |
That's why I'm in a tangle. The tokicos are for "lowered" applications and comparable to the TRD shocks, I thought when pairing up the "upgraded" shocks/struts like these with lowering springs, nothing needs to be cut. only with the stock shocks/springs because of how soft they are compared to the trd/tokicos.
I'm getting ready right now to go outside and install the springs and shocks! Wish me luck guys, I'll need it lol. Also, the spring settling period..is it based more on how much you drive or by time? I drive alot so I need to know if they will settle sooner because of that so that I don't wait too long to get the alignment. Or do they take time to settle no matter how much you drive? Last edited by detroiter; 05-20-2009 at 07:00 AM. |
#17 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
A good rule is about 2 weeks of settling. If you drive alot, then you'll be fine with 2 weeks.
#18 |
these front struts f'ing blow. having a bitch time getting off one side's top strut bolt. F'k you bolt!
| Rear point jack issue | bikegerm | General Yaris / Vitz Discussion | 11 | 09-25-2024 02:55 AM |
| Reinforce Jack points? | Morgan | DIY / Maintenance / Service | 41 | 11-10-2015 06:31 AM |
| DIY: Aux Input Jack Adapter | TinyGiant | DIY / Maintenance / Service | 11 | 11-10-2012 05:33 AM |
| DIY Aux Jack Install | Dave | DIY / Maintenance / Service | 11 | 02-17-2010 10:15 PM |
| Coud someone post pictures of the jack points on the Sedan & Hatch | voodoo22 | DIY / Maintenance / Service | 4 | 11-08-2008 08:24 AM |
