View Poll Results: Would these interest you ,if so what offset
0.5 Deg Camber 4 17.39%
1.0 Deg Camber 3 13.04%
1.5 Deg Camber 5 21.74%
2.0 Deg Camber 6 26.09%
2.5 Deg camber 3 13.04%
Good idea , but no thanks . 9 39.13%
Multiple Choice Poll. Voters: 23. You may not vote on this poll
Old 06-27-2009, 05:45 PM   #1
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Cambered Hub Spacer's , Interested yes / no
Hi Guy's and Girls
If these where on offer , would you be interested , would you purchase
The following fiquires are worked out from a 24" wheel size
http://www.yarisworld.com/forums/showthread.php?t=5021
The fiqures below show the wheel movement (offset) at the
top - and bottom + of the wheel, Relivant to the hub camber angle.
Proposal is this 12.5mm thick spacer's with possably the following cambers
--------------------Bottom -------Top
0.5 deg camber +2.66mm -2.66mm
1.0 deg camber +5.32mm -5.32mm
1.5 deg camber +7.98mm -7.98mm
2.0 deg camber +10.64mm -10.64mm
2.5 deg camber +13.30mm -13.30mm
This is an interest only thread , and if there is enough interest , they
will be put into production , and sold by a Regestered Vendor.
installing Penguin Garage rear hub spacers! Tamago DIY / Maintenance / Service 101 05-21-2011 12:29 PM
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 06:16 PM
Gauging interest on hub spacers for the yaris Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 61 05-22-2009 02:18 PM
looky who's getting hub spacers next! Tamago Off-topic / Other Cars / Everything else Discussions 5 05-18-2009 10:19 PM
15 dollar hub spacers ebay... YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 10-20-2008 01:24 AM
