View Poll Results: are you interested?
yes i'm interested in 13mm spacers 13 48.15%
yes i'm interested in 10mm spacers 14 51.85%
Voters: 27. You may not vote on this poll
Old 04-30-2009, 09:27 AM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Gauging interest on hub spacers for the yaris
i'm getting ramped up to build more hub spacers and want to get a semi-accurate count on how many i should build.
please choose "yes" in the poll if you'd be interested in spacers @ $75shipped to continental US (and reasonable shipping to canada too of course)
if the results are favorable i'll be getting a vendor account here :)
Old 04-30-2009, 09:35 AM   #2
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
ChaChaChaChino
Its a Chao!!!
Old 04-30-2009, 09:37 AM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
can i have a moderator edit this to become a public poll? thanks
Old 04-30-2009, 09:39 AM   #4
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
pm tk-421, he's been looking for this!
Old 04-30-2009, 09:44 AM   #5
gmodder
Riceman43
Drives: 2009 Yaris 3door
What do these actually do for you...
gmodder is offline   Reply With Quote
Old 04-30-2009, 09:50 AM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
they allow you to get your vehicle's track width closer to equal. the car normally comes with about 1" wider track front vs rear.
one of those "little" mods that you can actually feel in the corners
they also allow you to buy a "proper" offset wheel for the front of your car and space the rear out to look more flush (without rubbing). they're "better" than wheel spacers, as they do not require you to have longer lug bolts, and because you're spacing the HUB not the WHEEL, you do not see as much wear on wheel bearings.
will come with class 12.9 socket head capscrews (allen head) and hardened washers.
Old 04-30-2009, 09:58 AM   #7
kngrsll
Apexing Egg!!
kngrsll's Avatar
do you think you could make some that reduce the toe?
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 04-30-2009, 10:00 AM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
very difficult to do that, as i don't know the specific drop your car has. as the suspension compresses, negative camber turns into toe-in.
i could, however, provide two stainless washers to be installed under the lower front bolt. this is how i achieved my current setup (toe out, and a little extra camber)
Old 04-30-2009, 10:40 AM   #9
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
I've got the v 1.0s on our Yaris currently and they are great. Getting a 2nd set of 13mm's is kind of tempting though.
Keep me posted on the progress of this, count me in. :)
Russelt3hPirate is offline   Reply With Quote
Old 04-30-2009, 10:43 AM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
if you want to test how this would fit, i have wheels that'll essentially give you the same offset as 13mm spacers & your current wheel setup.
or were you thinking to ADD 13mm to your current 10mm?
Old 04-30-2009, 10:45 AM   #11
Russelt3hPirate
l33t3st Asshole
I was thinking of swapping the 10s for the 13s.
and keeping the 10's just in case.
the price is too good not to have 2 different sets, having the flexibility to easily change the rear spacing when I buy new wheels is really comforting.
Old 04-30-2009, 10:47 AM   #12
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
what's the difference between the 2 and do you think i need this mod?
Old 04-30-2009, 10:48 AM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
one is 10 mm wide
the other is 13mm wide
so the difference is 3mm
what wheel/tire are you running, and on what suspension?
Old 04-30-2009, 10:51 AM   #14
Russelt3hPirate
l33t3st Asshole
I think Every Yaris needs this, it really changes the handling/look, as they say you "need" a +42mm in the front to avoid rubbing, but you don't "need" a +42mm in the rear, hell I'm running a +25mm effective offset in the rear right now. :)
Old 04-30-2009, 11:09 AM   #15
BLAZINBLUEVITZ
one is 10 mm wide
trd evolution's on 215/35/18's with tein's.....
im stupid so the extra 3mm means it will stick out further than 10mm?
Old 04-30-2009, 11:10 AM   #16
33OH
Drives: '08 Yaris
The extra 3mm means it'll stick out 13mm, yes.
Old 04-30-2009, 11:17 AM   #17
Russelt3hPirate
l33t3st Asshole
what's the width/offset on the wheels
stick out isn't the correct term.
it will push the wheel outward 13mm total from where it is now.
it will not stick out unless you have an offset of 30mm or lower to start with.
Old 04-30-2009, 11:18 AM   #18
BLAZINBLUEVITZ
+42 i think
WANTED - Stock 15" 2007 Yaris HUB CAPS! Chris07LB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-29-2006 07:09 PM
