Old 07-21-2009, 06:35 PM   #1
captainm27
Drives: 2008 Sedan A/T Silver
Question about the Engine Overheating LED
Hi! I have a quick question about the temp overheating led: If the light comes on, does that mean that the temp has reached so high that engine damage has already occurred? Or, does it have some kind of range? Like for example, (I don't know engine temp ranges, so I'm just using numbers here), let's say the engine normal range is 250 degrees, and that the maximum operating temp is 300 degrees. Would the light come on before it reaches that temp limit, thus allowing one to safely pull the car to a safe spot? Or does that light come on when it's already too late?
captainm27 is offline   Reply With Quote
engine question... (2ZR-FE and 2ZZ-GE) Avia General Yaris / Vitz Discussion 5 12-24-2010 08:16 AM
LED tail light question Julz Cosmetic Modifications (Exterior/Interior) 4 06-19-2009 09:25 AM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 10:53 AM
Check Engine Light Question falkor_99 General Yaris / Vitz Discussion 11 07-22-2007 05:15 PM
Engine Question? N.Y.YARIS Performance Modifications 8 04-03-2007 10:08 PM
