Old 08-26-2009, 11:23 AM   #1
SweetRS
Drives: 2006 Yaris Rs
Rear Hub Spacer camber?
Do the rear hub spacers change camber at all?
SweetRS is offline   Reply With Quote
Old 08-26-2009, 11:25 AM   #2
Brentorius
Drives: 07 Mazda MX5 Copper Red
No
Brentorius is offline   Reply With Quote
Old 08-26-2009, 11:29 AM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
rear hub spacers from penguingarage.com come with camber shims, they add about -1deg of camber.
Old 08-26-2009, 11:40 AM   #4
SweetRS
is it possible to add the shims that Garm sell aswell as the shims that are on the spacers?
Old 08-26-2009, 11:48 AM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
i don't know what garm sells, please post a picture
Old 08-26-2009, 11:51 AM   #6
SweetRS
http://shop.microimageonline.com/pro...7&categoryId=4
Old 08-26-2009, 11:52 AM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
no, they won't work together.
i don't recommend using plastic shims anyway
Old 08-26-2009, 11:56 AM   #8
SweetRS
well, i gotta do something, , need answers!! lol
Old 08-26-2009, 11:58 AM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
ask the question please, you haven't asked or told why you want to combine shims?
Old 08-26-2009, 12:32 PM   #10
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
if you want more camber you dont need to combine shims
Its a Chao!!!
Old 08-26-2009, 12:45 PM   #11
SweetRS
how do i get the most negative camber in the rear? if i decide to stuff wider wheel/tire (15X8, 195/45/15) back there and have it fit...with rolling the fender ofcoarse
Old 08-26-2009, 01:36 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
if you want more than an extra 1-2 degrees rear camber, you'll want to look into custom shims. Penguin Garage toyed with the idea as well as the Kiwi, but no one bit. no point in spending hundreds on R&D to sell one measly set of camber shims.
you could always stack the shims from penguingarage ;) put two under each lower bolt each side, get an extra 2deg camber. not recommended, but iv'e seen it done on the honda fit with no ill effects.
Old 08-26-2009, 01:51 PM   #13
SweetRS
Hmmm, interesting! hey if hondas can do it so can we...im just curious though, would i need longer bolts for that kinda operation?and if there is a slight angle of the hub are the bolt still gonna fit properly? maybe i don treally understand how these work
Old 08-26-2009, 02:00 PM   #14
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
The bolts supplied by PG are plenty long enough I think. There was more than enough length for my 10mm spacers and I imagine adding 2 shims won't be a problem for the bolt length.
Old 08-26-2009, 02:37 PM   #15
SweetRS
oh i didnt notice that bolts came with it...sweet...
Old 08-26-2009, 02:44 PM   #16
SweetRS
what do the shims from penguin garage look like??
Old 08-26-2009, 02:56 PM   #17
MUSKOKA800
MUSKOKA800's Avatar
Have you checked with an alignment shop to see what they'd us to correct extreme positive camber situations (colision repair etc)?
When I had a 4 wheel alignment done the alignment rack did measure those spec's. the tech said the toe was slightly out at one of my rear wheels but not enough to be concerned. He said if I noticed odd tire wear to come in and they'd address it. With shims behind the brakes I assume.
Old 08-26-2009, 03:00 PM   #18
SweetRS
yah i work at a Toyota owned collision repair shop, so, i had an alignment done when i put the springs on...toe was in ever so slightly...
so, what do the shims for the spacer look like??
installing Penguin Garage rear hub spacers! Tamago DIY / Maintenance / Service 101 05-21-2011 12:29 PM
Adjusting rear camber?? PHXDEMON Wheels, Tires and Suspension Forum sponsored by The Tire Rack 63 10-23-2009 12:11 PM
New Product: Penguin Garage Rear Camber Shims! Penguin Garage Penguin Garage 11 10-22-2009 10:20 PM
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 06:16 PM
Penguin Garage Rear Hub Spacer Raffle!! Penguin Garage General Yaris / Vitz Discussion 27 06-30-2009 01:05 AM
