Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Marketplace > Sponsors Classifieds Area > Penguin Garage
Old 06-24-2009, 02:20 PM   #1
Penguin Garage
Penguin Garage's Avatar
New Product: Penguin Garage Rear Camber Shims!
Hello YarisWorld!
Penguin Garage is pleased to announce a low cost rear camber solution
for the Toyota Yaris!
* Works with Penguin Garage Hub Spacers as well as unmodified Yarii
* Adds around 1 Degree of negative camber to the built in factory
alignment specs (varies by amount of lowering, etc)
* made from 316 Stainless Steel
* Precision machined to clear hub pilot diameter and add uniform camber
Each kit includes:
4 camber shims (two each side) to be installed between the lower hub
bolts and the spacer (or axle in stock applications)
Pricing:
Camber kit alone, $15 shipped to any US state/territory (out of
country buyers please PM for very reasonable rates!)
Camber kit if purchased with a set of rear hub spacers, $PM for Special Pricing
to all of our previous customers who have already purchased spacers
and want the extra clearance gained by these washers, PLEASE PM US for
your special pricing!
(note, spacer and bolt not included )
Penguin Garage is offline   Reply With Quote
Old 06-24-2009, 02:58 PM   #2
What's the difference between that and buying some washers and cutting them like that?
Old 06-24-2009, 04:13 PM   #3
Is the material different?
Old 06-24-2009, 04:14 PM   #4
Penguin Garage
We released these so you guys don't need to modify them to the correct size.
these are all the same, so no worries of modifying,testing,modifying,testing and so on. Just slip them in and enjoy the added camber. (Professional alignment suggested).
Old 06-24-2009, 04:16 PM   #5
Penguin Garage
Garm, these are stainless washers. We didn't go exotic on the materials to help keep costs down.
Old 06-24-2009, 04:27 PM   #6
Thanks. I think that helps our customers.
Old 06-24-2009, 04:32 PM   #7
Penguin Garage
No problem
We just picked these up today and they are ready to ship.
Working on adding these to the website soon.
Old 07-16-2009, 01:19 PM   #8
misformartin
Drives: xd
pmed
misformartin is offline   Reply With Quote
Old 10-15-2009, 10:13 PM   #9
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Query: I recently tried the plastic camber plates/shims and they didn't really work-out very well, so I'm exploring other options. I don't really need to add more negative camber, but I really want to eliminate the factory toe-in. I'm not rolling over the rear tires, even in hard cornering on concrete, and the car rotates reasonably well. I don't mind if I get a little more negative camber, but that's not a priority. Is there a configuration with these shims that will achieve zero or VERY slight negative toe-in?
Second, if I have my current alignment numbers, can we calculate fairly-precisely the degree of adjustment that will be made to each side?
Old 10-15-2009, 10:31 PM   #10
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Received my shims a couple of days ago. Getting them installed tomorrow.
Thanks for the great service!
Old 10-22-2009, 10:06 PM   #11
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Finally got these installed... Got a chance to drive around a bit, and I like the new feel, although somehow my suspension is sitting a bit too high at the moment... I guess that will pass after a couple of days.
Old 10-22-2009, 10:20 PM   #12
YAR1S
YAR1S's Avatar
these came free with the spacers right??
how come they cost now, just wondering....
I suppose if you only want the shims it would make sense....
I never installed them because I was unsure of the uneven surface that would be caused by adding them....
what would be cool is if you made angled shims and adjacent shims that would let the hub sit flat on them instead of there being a gap.
still, thanks for making this stuff for the yaris, Im really loving my PG13's and cant wait for some new wheels to really see the more flush look :D
-Jen <3
installing Penguin Garage rear hub spacers! Tamago DIY / Maintenance / Service 101 05-21-2011 12:29 PM
Adjusting rear camber?? PHXDEMON Wheels, Tires and Suspension Forum sponsored by The Tire Rack 63 10-23-2009 12:11 PM
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 06:16 PM
Penguin Garage Rear Hub Spacer Raffle!! Penguin Garage General Yaris / Vitz Discussion 27 06-30-2009 01:05 AM
Urgent Peanut Product Recall Bob_VT Off-topic / Other Cars / Everything else Discussions 5 02-08-2009 01:03 PM
