Old 01-01-2009, 08:38 AM   #1
goku87
goku87's Avatar
Drives: Black HB
Question Current draw on battery, possibly glowshift gauges?
I have three glowshift gauges installed, volt, rpm, and water temp. I have had them installed for a while, but recently I have been noticing some issues with my battery. Every time I go to start my car I have to get a jump start. I thought it was just the cold + a bad battery, but when I took it in, the dealership said that there was something pulling more current than normal. I think he said it was somewhere around 330mA. Is it possible that my gauge cluster is causing this?
goku87 is offline   Reply With Quote
Old 01-01-2009, 10:27 AM   #2
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
the 3 gauges wont draw nearly enough power to make even the slightest difference.
Old 01-01-2009, 04:05 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
300mA is not going to affect anything. It's like 1 extra 5w light bulb. lol
Old 01-01-2009, 04:59 PM   #4
Desperauto
The Old Man
Desperauto's Avatar
Drives: 2008 yaris HB black sand pearl
Interesting my HB is one year old and the battery did the same thing, I have gauges also and a stereo amp +++ and an alarm system. The battery would keep going dead. I realize that the alarm pulls current but not that much. I finally put the battery under and extreme test and found that one of the cells in the battery was shorting out and draining the battery. They must use cheap batterys in the factory install. It gave me the excuse to put in a yellow top, even though they cost 3 times as much.
Life is Grand
Desperauto is offline   Reply With Quote
Old 01-01-2009, 08:28 PM   #5
IllusionX
Panasonic seem to be making pretty bad batteries lately. I'm hearing several cases of OEM batteries going bad. But Toyota dealers here replaces with "toyota" batteries, mfg'd by East Penn, and are 550amp vs 330amp panasonic.
Old 01-02-2009, 07:34 AM   #6
goku87
goku87's Avatar
Drives: Black HB
Unhooked the power from the gauges. Battery was fine many many hours later. Why are my gauges pulling so much current?
Old 01-02-2009, 07:54 AM   #7
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
They do. My completely stock Yaris (minus speakers that draw nothing while they're off) needed a boost the other day. POS car...
Old 01-01-2009, 05:47 PM   #8
ChinoCharles
Drives: LB
Make sure your stereo systems are grounded.
Old 01-01-2009, 08:08 PM   #9
goku87
goku87's Avatar
Drives: Black HB
Interesting. Well, I disconnected the gauges last night so I could see if I needed a jump start this morning. Just to see if it was the gauges. I couldn't find my multimeter to actually measure the amperage.
I have the stock stereo system. :(
Old 01-02-2009, 12:03 PM   #10
mikenacarato
SIPNDEW
Drives: 15 STI
your gauges wouldnt have anything to do with the battery dying, unless you have the power wire tapped into a constand 12v source. they do turn off when the car is off right?
Old 01-02-2009, 09:02 PM   #11
goku87
goku87's Avatar
Drives: Black HB
Correct. The +12v is connected to +12v and the ACC is connected to the ACC, so when the car is off, the guages go off. I tapped off of the guage cluster wires. Thought that was appropriate.
Found my multimeter last night. I'm going to confirm that it's my gauges, and then try to figure out which gauge it is. But I really don't want to with it being so cold out. -16F is just cold.
Old 01-03-2009, 06:14 AM   #12
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
330ma hahaha... thats a 4watt drain. yeah... that will take a long time to drain a battery
equation is Amps * Volts = watts
.330A * 12V = 3.96watts
check all your aftermarket electronics... lights, glowing dash crap, stereo... make sure that none of the connectors have any strands of wire that is frayed out and can possible short out on metal somewhere. That could cause a short which might speed up the discharge rate.
Old 01-03-2009, 08:41 AM   #13
goku87
goku87's Avatar
Drives: Black HB
Exclamation I guess I need to clarify:
With the exception of the gauges (which are now disconnected) I have no aftermarket electronics in the Yaris. And to my surprise, I found out about an hour ago I could not start my car because the battery had gotten to low. It did just the "click-click-click-click-click-click" thing cars do when their battery isn't dead, but low.
What could possibly be draining my battery???
Old 01-03-2009, 10:20 PM   #14
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
My stock battery died after leaving the headlights on for 10 minutes without the engine running. I've owned many cars over the years and never had one go that quickly. Replaced it immediately with a Red Top.
I would agree that the stock batteries are crap - or at least there is a bad batch of them running around out there.
Old 01-04-2009, 03:42 AM   #15
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
There's more to checking if an alt or battery is good then just checking the voltage. The amperage is also important. if your alt can charge at 14v but only puts out 20amps at 3000 rpms, then something is horribly wrong.
its much harder to check amperage however as you need an ammeter/amp clamp which are spendy.
Old 01-04-2009, 06:49 AM   #16
goku87
goku87's Avatar
Drives: Black HB
Lucky for me I work on electronics, and an ammeter I have. I'll check that next. About how many amps should I be looking for?
Old 01-04-2009, 06:15 PM   #17
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I have no clue what a fully charged battery should be dumping for current.... your Alternator should dump something like 60-80amps in the range of 2000-3000rpms. At idle it'll be much lower, maybe as low as 15amps.
Alts usually max out in the 2-3k range.
Old 01-04-2009, 07:12 AM   #18
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Though it may seem too early to get a new battery considering that's it's still a pretty new car - get a new battery.
Battery Current Drain karlb General Yaris / Vitz Discussion 3 12-09-2008 04:28 PM
glowshift gauges combo, DF tanabe spring, + leather boot for sale cdmyaris Items for Sale by private party 19 09-28-2007 03:33 AM
