Old 12-09-2008, 01:46 PM   #1
karlb
Drives: Vitz 2006
Battery Current Drain
I have a 2006 Vitz 1.0L Automatic.. Is it normal that when switched off ( even with the key taken out) it consumes 170mA??
karlb is offline   Reply With Quote
Old 12-09-2008, 02:20 PM   #2
PaidTimeOff
OMGWTFKITTYKATMEWMEWMEW
Drives: 2008 Yaris S
Sounds normal to me. Batter has to be running to some of the electrical equipment. This is why you don't have to reset the clock every time you start up the car but do have to if you disconnect the battery. 170mA isn't a lot. My touchscreen cell phone uses about that much when I turn on the screen to check the time.
PaidTimeOff is offline   Reply With Quote
Old 12-09-2008, 04:03 PM   #3
karlb
Drives: Vitz 2006
So this is not the case that i have a short or a leak somewhere!! this is normal!?!?!? has anybody checked, ever??
Old 12-09-2008, 04:28 PM   #4
BailOut
Steals terrorist's lunch
BailOut's Avatar
Yes, that is a normal drain amount. I measured it while watching the effects of my solar trickle charger on the 12V battery.
Also keep in mind that even without any devices drawing current the battery still leaks some charge through gassing off. This is true for all rechargeable battery types but it is especially an issue with unsealed batteries. Most autos, including the Yaris, come with an unsealed battery (flooded lead acid).
- Brian
Share the Road
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
battery power question TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 22 12-05-2008 08:37 PM
6lb 6oz ultra light weight battery heavystarch Performance Modifications 28 11-19-2008 06:02 PM
Where to get ring connector for positive battery terminal? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 7 11-13-2008 11:44 PM
battery relocation redduck Performance Modifications 4 09-14-2007 07:53 PM
