Old 11-13-2008, 01:51 AM   #1
IsLNdbOi
IsLNdbOi's Avatar
Where to get ring connector for positive battery terminal?
I need to connect a 4 gauge power wire to my battery. I measured the positive battery terminal in my Yaris and it is around 3/4" in diameter. Where can I get a ring connector similar to this:
that will fit a 4 gauge wire and has a ring w/ an internal diameter of at least 3/4"? I've checked RadioShack and Fry's Electronics, but neither had rings big enough.
Old 11-13-2008, 02:40 AM   #2
pinoypizzaboy
Drives: 08 toyota yaris LB
try going to stereo stores like audio express/ss audio and stuff they prolly have it.
pinoypizzaboy is offline   Reply With Quote
Old 11-13-2008, 07:06 AM   #3
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
http://www.partsexpress.com/
Shipping for one little item would be prohibitive.
Old 11-13-2008, 07:09 AM   #4
IsLNdbOi
IsLNdbOi's Avatar
I've already checked Parts Express. I don't see a ring connector there that takes 4-gauge wires and has a ring that's 3/4" in diameter.
Old 11-13-2008, 11:20 AM   #5
Revsson
You might want to try a local electrician supply store. Sounds like you want a power
connector. Here is one place to search for sizing and style:
http://www.panduit.com/Products/Prod...tors/index.htm
One distributor might be:
http://www.newark.com
or try:
http://www.digikey.com
but you might have to buy in bulk, so best to try the local supplier. You can also try
an auto parts store like NAPA.
Why not just connect to the bolt that holds the positive cable to the battery post?
I am assuming this is for some audio power amp or something?
Old 11-13-2008, 11:35 AM   #6
Revsson
Just had another thought. Since you live in Las Vegas, why not try the
Amateur Electronics Supply store there? It could be that some ham radio guys
have installed a power cable of that size.
http://www.aesham.com/lasvegas.shtml
Just a thought.
Let us know if you do find the answer.
Old 11-13-2008, 09:32 PM   #7
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
carquest, or any auto parts store can usually get a hold of them... if they don't have them in stock... Big trucks sometimes use big connections.
Carquest over here carries up to 4/0 (like 1/0 but bigger).
I was able to find a 2/0 to connect my 2/0awg cable.
Old 11-13-2008, 11:44 PM   #8
sportin83
Drives: 2008 blazing blue yaris LB
circuit city or best buy should have them
http://cardomain.com/ride/3151056
mods: custom sub box, i hit 141.4 db, new speakers, double-din nav, foglights, cruise, CAI, strut brace, under car braces, short antenna, remote start, alarm, actuators in doors and hatch
coming soon: window tint, custom sub grills, tach and........
sportin83 is offline   Reply With Quote
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
6lb 6oz ultra light weight battery heavystarch Performance Modifications 28 11-19-2008 06:02 PM
battery relocation redduck Performance Modifications 4 09-14-2007 07:53 PM
Urgent:Stupid problem with battery Katana DIY / Maintenance / Service 8 09-02-2007 10:36 AM
Buying a diamond engagement ring BMGYaris Off-topic / Other Cars / Everything else Discussions 20 06-20-2007 09:23 PM
