Old 09-23-2009, 09:26 AM   #1
Gulinu
Drives: vitz 2006
Questioning about Idling
Hi I have a Toyota Vitz(Yaris) `06, automatic (cvt) 1.0ltr, i ve connected it to a computer and the idling speed is about 750rpm , which is normal. But when you stop and put your leg on the brake it vibrates for a small while and then it settle.
Is it normal or is it a problem ? And if you compare it with another yaris 1.3ltr does it vibrate the same ?
Thanks
Gulinu is offline   Reply With Quote
DIY - 1.8L 1ZZ-FE TB Connector Chip Swap Yaris T-Sport DIY / Maintenance / Service 332 04-03-2022 01:39 AM
adjust idling Yaross DIY / Maintenance / Service 13 02-04-2010 06:47 AM
