Old 07-14-2009, 02:19 PM   #1
ExocetCom
ExocetCom's Avatar
Drives: 2007 Toyota Yaris RS
Jack Stand "Rubber Attachments"?
In preperation for doing the first bit of personal maintenance on my 07 3dr LB, just an oil change, I've been reading through some of the Toyota factory manuals (FM) that have been so kindly posted here. In the introduction chapter, which includes information on jacking up the car, the FM mentions "rubber attachments" for jack stands. In the FM diagrams they just look like rubber blocks with a slit in them which would be set around the pinch weld. I presume these are to prevent bending the pinch weld where the jacks would normally go.
Question is, can I get these from my Toyota dealer's parts department or is this the kind of thing I could go to a comprehensive auto parts store and buy?
ExocetCom is offline   Reply With Quote
Old 07-14-2009, 04:23 PM   #2
Hockey pucks work great. I run them through the tablesaw a couple of times to put about a 3/8" wide by 1/2" deep groove in them.
Old 07-14-2009, 04:24 PM   #3
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
+1 on this.
Old 07-14-2009, 05:18 PM   #4
POORSHA
POORSHA's Avatar
Drives: 2008 LB
+1
POORSHA is offline   Reply With Quote
Old 07-14-2009, 07:13 PM   #5
PhilD424
Drives: Red Yaris
Eh the worst place to jack up a car is at that jacking point. Find another spot. And when you jack the proper way to do it is to use wood to go in between the jack and the frame of the car.
-Phil
PhilD424 is offline   Reply With Quote
Old 07-14-2009, 07:33 PM   #6
ExocetCom
ExocetCom's Avatar
That's an awesome idea, thanks!
Old 11-30-2009, 01:17 AM   #7
guyver408
Drives: 2009 Yaris 5dr
Factory advised jack points?
Can you post a link to the FM or page/diagram which shows jack points - i'm curious as to the best points to jack the car.
Note: I really don't like the ones shown for emergency jacking in my 2009 hatchback manual.
guyver408 is offline   Reply With Quote
Old 11-30-2009, 06:53 AM   #8
Old 11-30-2009, 09:27 AM   #9
MUSKOKA800
MUSKOKA800's Avatar
My aero sedan has the front lip. When I pushed my floor jack under far enough to reach the front jacking point there is insufficient clearance to pump the handle (up-down). When installing my TRD suspension I drove up onto blocks first before jacking and dropped it back onto the blocks afterward when the chassis/body was even lower.
The rear jack point is indeed quite handy.
Old 11-30-2009, 01:05 PM   #10
bronsin
bronsin's Avatar
Ive been lifting/supporting cars using the jack points for 30 years and never used a rubber thingy! What happens if the weight of the car splits the wood/hockey puck/rubber pad?
Old 11-30-2009, 01:21 PM   #11
I use the grooved hockey pucks when jacking from the sides. The puck is centered on the jack plate, so if the puck splits, the car would come down less than 1/2" onto the plate.
Wood worries me - I use a piece of 4x4 when jacking my lifted Xterra. If the wood split or rotated, the 3-1/2" of travel could be disastrous, so as I jack it, every couple of inches, I keep raising my jack stands.
Old 11-30-2009, 04:18 PM   #12
bronsin
bronsin's Avatar
Ive heard of people using concrete blocks to jack cars up on and the concrete crumbles suddenly...
Rear point jack issue bikegerm General Yaris / Vitz Discussion 11 09-25-2024 02:55 AM
DIY: Aux Input Jack Adapter TinyGiant DIY / Maintenance / Service 11 11-10-2012 05:33 AM
DIY Aux Jack Install Dave DIY / Maintenance / Service 11 02-17-2010 10:15 PM
Jack Stands - GTA CB900F2 DIY / Maintenance / Service 5 06-19-2009 06:56 AM
