Old 03-21-2010, 09:49 PM   #1
az_saguaro
What to Mod Next?
Drives: 2008 3Dr HB, Bayou Blue
Pic of my new E-Brake handle
I installed a NRG E-Brake handle yesterday and took a pic to share. The handle is the universal brushed aluminum. I ordered from Andy's Auto Sport for $22. You can also see the leather shift and ebrake boots supplied by Garm. Installation isn't for the light hearted. To get a good fit I had to first remove the ebrake boot. I had heard that it may be possible to remove the plastic handle by pulling it straight towards the front of the car. However, mine didn't budge, not even a little, no matter how I persuaded it. So I used my dremel to cut two small paths down the top center of the handle. Then using an old flat blade screw driver and a hammer I chipped away the handle. At first it took a bit of hammering, but once the first couple of pieces chipped out the rest of the handle broke away easily. After the handle was off I unscrewed the button and cut the black part of the button off leaving the full yellow part. To get the best fit possible for the new handle, using a hacksaw I had to cut about 3/8" of the aluminum lever that equates to about the middle of the hole in the top of the ebrake handle. After that, the handle slid on the remainder of the lever and fit nicely, the leather boot slides up over the set screws in the handle and fits beautifully into a ring cut into the handle for just this reason. It matches the OBX shift knob from Toyota perfectly.
az_saguaro is offline   Reply With Quote
Old 03-21-2010, 11:41 PM   #2
heeroyuy01195
Post count means nothing.
looks awesome, so the stock button just screws off like a normal bolt?
Old 03-21-2010, 11:52 PM   #3
az_saguaro
What to Mod Next?
The stock button is two pieces, a black cap (the part you see) and a nylon threaded insert (translucent yellow and hidden by the handle). I believe the cap is pressed onto the insert. I originally started to sand the cap down as it didn't pull off easily. After I tried that on the new handle, it was still a bit too long. So, I started to cut the cap off and about halfway through the entire cap popped off. Which is exactly what I wanted. With the cap off the new button cap slid on easily. Then I just screwed it back onto the threaded rod that runs down the center of the lever to latch pawl.
Old 03-22-2010, 12:53 AM   #4
QR25DE_SpecV
QR25DE_SpecV's Avatar
Drives: 2006 Sentra SpecV
Not my cup of tea. Spells autozone special to me.
It's not what you drive, but what drives you
QR25DE_SpecV is offline   Reply With Quote
Old 03-22-2010, 04:54 AM   #5
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
not bad... matches your shift knob and pedals well
Old 03-22-2010, 09:48 AM   #6
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
+1
If not for those 2 other things, then yeah it would look wack, but it looks good as a whole. also seems to go well with the rest of the silver paneling in the yaris so its a good theme. +2
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Help me pic my best pic... Sabretooth Photo-Video-Media Gallery 17 06-14-2009 07:52 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
