Old 05-23-2010, 02:07 AM   #1
Herbicidal
Just a Herbicidal maniac.
Herbicidal's Avatar
Drives: 2008 Yaris S Sedan Flint Mica
Driver door won't open, jammed cable?
Well I think I'm screwed in a big way. I spent most of today sound deadening the drivers door. I finally finished, reconnected the two cables for the lock/latch mechanism, the plug for power to the door locks and windows. I climbed in and the door didn't want to latch when it was shut. I cycled the power door lock switch a few times and tried again. This time it shut, but now it won't open. I've tried the key outside in the door, cycled the door locks and it won't open. I think perhaps when I put the main panel back on, it might have applied too much pressure on one of the cables therefore not allowing it to release the latch. Or, it popped out of the notch that was holding in place and is essentially no longer connected to the door handle.
I don't think I can even get the panel off with the door closed. I'm about ready to bust out my cutoff wheel and destroy the panel to get the blankity blank door open, yes, I would have to buy a new door panel. Any suggestions before I go all Rambo on it? What a crappy way to end this day. It had been going too well apparently.
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace.
Herbicidal is offline   Reply With Quote
Disable beep when driver door open and key in ignition fmicle DIY / Maintenance / Service 7 05-03-2018 06:30 PM
Cannot open the driver door when unlocking from the outside. Rahxephon DIY / Maintenance / Service 10 12-02-2006 10:18 AM
