![]() Drives: Toyota Yaris 3dr Join Date: Aug 2010
Pedals
I was wondering if anyone had installed some aftermarket pedals?
If so what brand and if possible a DIY would be great. The only pedals I have found that I really like are those cheap ones that you find in discount for 22$. I think they are the Pilot motorsport brand which only installs by clamps. I have been considering this for a while but are the clamps safe? Im not in the mood to be drilling holes into my pedals. Thanks for the input. |
I bought these from Toyota.
They slip right on and require no drilling or screws or clamps.
Never take eyes off opponent - Bruce Lee |
![]() ![]() ![]() Drives: 2010 NCP91 5spd Join Date: Nov 2009
My experience with pedals is that they ALWAYS slip off, no matter how expensive the brand. They only way to make certain is to drill them on, or you use the OEM slip on covers (since they are custom formed, they are near impossible to accidentally slip off).
I don't know, but they're just pedals. . . is it worth having an accelerator/brake/clutch malfunction because you wanted pretty pedals? Be safe about it. . . drill or buy OEM. |
![]() ![]() ![]() Drives: yaris1.33 Join Date: Jul 2010
auxmike : how much did you paid for them ?
![]() ![]() ![]() ![]() Drives: 2010 Yaris S Join Date: Apr 2010
Get the Toyota ones..they fit VERY securely
"In his heart a man plans his course, but the Lord determines his steps." Proverbs 16:9 |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
I've had these on my car for like 3 years never had a problem with them
![]() ![]() ![]() Drives: 2008 5-door Yaris Hatchback Join Date: Oct 2008
I have the Genuine Toyota sport pedals; never a problem and fit perfectly.
To clarify, when I said OEM, I meant the OEM slip on upgrade covers, like auxmike mentioned. I have the same ones on my Yaris, and the same on both my xA and tC. They're usually around $40-60.
that is reasonable price. it look nice I think I will go for them ;)
They fit on real tight and look great!
For me, it's always been about function. I have huge feet so I never slip my foot off the pedal... But because of Toyota's upright seating position, you don't really push forward and back on the pedals, but rather down, causing the pedal to go forward while the foot slides backwards on the pedal, as the heel is planted. Proper operation would result in lifting the heel off the ground, unsupported, which is not doable. Normally it's no issue, but if it's raining and my shoes got wet from outside, the rubbing on the rubber pedal causes an ungainly squeaking noise, like a worn out windshield wiper blade, and it drives me nuts. Metal pedals solve this problem. It's not an issue with lower seated cars with feet stetched out in front of you. Normally, cars, trucks, and busses with upright seating have pedals that feed into the floor, with the axis of rotation near the heel, rather than under the dash...
Word of advice about installing the Toyota pedals is to soak them in hot soapy water for several minutes prior to installing them
#13 | |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
You have to remove the OE covers, and drill some holes, but it is an easy mod. http://www.sparcousa.com/ptuning_pedals.asp?id=339
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
#14 |
^ those are nice. Jason, is heel/toe easy for you in this car? I think the gas pedal is a little far back to make that easy. I took off my clutch and brake pedal covers and replaced them with grip tape - that gave me a 1/4" change.
#15 | |
![]() No, heel/toe in the Yaris is a pain, it is one of the most frustrating cars I have found. We went the other way and put a 1/4" aluminum spacer under the brake pedal cover to help even it up with the throttle. I also changed to a low top driving shoe to help get enough articulation, even then I often found myself pegging the throttle and banging the limiter on downshifts. I was ready to change the pedals again, but we found moving the steering wheel and seating position (further back and down) seemed to fix the problem. I did not have any problems at the Miller race with the new setup.
#16 |
I took the leap and bought the cheap discount auto parts pedals. I am pretty happy. The quality isnt the best but I didnt pay much for them. I will take a picture one of theses days and post it. Next up on my list is to find that 12 walmart exhaust part. : )
#17 |
Free Mustache Rides
bargain buyer, eh? good choice
#18 |
Hopes & Dreams
In regards to the genuine Toyota sports pedals? What exactly is involved with installing? Do they just sit on top of the stock pedals or do I need to remove the stock pedals and replace them with the genuine sports pedals?
| pedals for yaris LB | kaymm | Cosmetic Modifications (Exterior/Interior) | 20 | 07-05-2009 11:36 AM |
| WTB:Stock rubber Pedals or other pedals | KSIbucky | Willing to Buy by private party | 3 | 02-23-2009 08:28 PM |
| Plastic Pedals? WTF! | tk-421 | General Yaris / Vitz Discussion | 4 | 09-02-2007 06:14 AM |
| Does anyone have more pics of these OBX pedals? | Mead | Cosmetic Modifications (Exterior/Interior) | 3 | 05-24-2007 01:45 PM |
| Sport Pedals | riceboy | Cosmetic Modifications (Exterior/Interior) | 16 | 10-16-2006 01:16 PM |
