Old 09-07-2006, 03:01 PM   #1
kaymm
kaymm's Avatar
Drives: Yaris Liftback 3dr (Silver)
pedals for yaris LB
Ordering a 5spd manual. Would like to get some nice pedals for it in advance, do I have to get ones specifically for the yaris or are pedals like OBX universal?
kaymm is offline   Reply With Quote
Old 09-07-2006, 03:42 PM   #2
Sparks Toyota-TRD
Drives: Toyota/Scion
Pedals are going to be different car to car, so it's a good idea to by model specific parts. Here's a link to the OBX ones we have. Hope this helps.
http://www.trdsparks.com/displaypart...&parts_id=1105
Ken
www.trdsparks.com
Sparks Toyota-TRD is offline   Reply With Quote
Old 09-07-2006, 03:45 PM   #3
dngz
dngz's Avatar
Drives: black yaris sedan
ive got universal fit RAZO GT Spec Carbon Fibre Sports Pedals from ebay. They feel pretty good and they look awesome!
dngz is offline   Reply With Quote
Old 09-07-2006, 04:00 PM   #4
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Αre they better than the original ones as far as the feeling is concerned?
Old 09-07-2006, 04:25 PM   #5
kaymm
kaymm's Avatar
Also I don't want to do any drilling or unreversable damage to the pedals? Do they just clamp in?
07 Yaris LB 3dr
Silver Mica
5sp manual shift
Old 09-07-2006, 04:27 PM   #6
TC-LIFTBACK
Drives: 2007 Liftback
Ebay pedals $21 shipped
I bought these ones off of ebay for 21 bucks shipped. They included a deadpedal that I reworked and threw into my car. I'll post pics tomorrow.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
I like them, they feel nice, they look nice and clean. They have the rubber grips which help your shoes feel secure.
-Ben
TC-LIFTBACK is offline   Reply With Quote
Old 09-07-2006, 04:30 PM   #7
kaymm
kaymm's Avatar
Ken
www.trdsparks.com
Those look like nice ones and they are perfect for my new 07 yaris! How do those mount? Do they screw and clamp? Basically i want something that i can remove later on without people knowing I ever put those in.
07 Yaris LB 3dr
Silver Mica
5sp manual shift
Old 09-07-2006, 04:40 PM   #8
Sparks Toyota-TRD
Pedals
They are designed to slip over the existing pedals and can be removed whenever you'd like.
Ken
www.trdsparks.com
Old 09-07-2006, 07:22 PM   #9
dngz
dngz's Avatar
the ones i have, each petal comes with a small metal bracket that you clamp and tighten onto the original pedal. you can remove it whenever you like. the actual pedal itself bolts onto the metal piece that was just attached to your pedals.
as for feel, i noticed right away that the pedals were more sensitive. with my stock pedals, my clutch felt extremely short and 5 people (including me) who knew how to drive manual couldnt start the car cuz my clutch had to be nudge to the very back where it's touching the back wall. Now I have no problem and the people who drove my car again asked me if i adjusted my clutch but i just told them i put sports pedals.
Old 09-08-2006, 03:14 AM   #10
Katana
Katana's Avatar
Νice result anyway.
Old 09-08-2006, 10:58 AM   #11
kaymm
kaymm's Avatar
Is it snug? no moving and vibrations? I hope they don't feel loose if you're just clamping them in place.
Do they make the original pedals wider?
07 Yaris LB 3dr
Silver Mica
5sp manual shift
Old 09-08-2006, 11:00 AM   #12
kaymm
kaymm's Avatar
Ken
www.trdsparks.com
What is your typical shipping times for orders to Canada?
07 Yaris LB 3dr
Silver Mica
5sp manual shift
Old 09-08-2006, 11:05 AM   #13
Sparks Toyota-TRD
Pedals
We usually ship the same day and depending on which side of Canada you're on, it can take from 2 to 5 days to reach customs. Hope that helps.
Ken
Old 09-08-2006, 01:37 PM   #14
Katana
Katana's Avatar
The installation is easy?
Old 09-08-2006, 05:59 PM   #15
kaymm
kaymm's Avatar
Nice, how much you pay and where di you buy?
Originally Posted by echo_hrs
The dealer OBX yaris specific pedals are the best (like OEM) fit... No screws, no clips to get stuck on your carpet, they fit just like the OEM rubber, and won't shift or fall off. They are the same size and shape as the OEM rubber...
You remove the stock rubber from the brake and clutch. Then you use a soapy water solution to make the rubber back of the OBX pedals easier to slip over the metal bases of the pedal, so they fit nice and tight just like the OEM rubber pads.
The gas pedal just slips over the gas pedal because the gas pedal is one moulded piece of plastic...
They fit like the OEM rubber, and you can easily swap them back to stock...
Cheers
07 Yaris LB 3dr
Silver Mica
5sp manual shift
Old 09-08-2006, 06:00 PM   #16
dngz
dngz's Avatar
They're pretty snug.. Mine are slightly crooked cuz when i was installing it, i was installing it in my carport at night with a flashlight (too excited to put them on, couldnt wait for the morning!!). The instruction sheet also said to tighten each pedal every 1000km to ensure safety. And yes, they do make your pedals a little bit wider.
Old 09-08-2006, 07:07 PM   #17
Chris07LB
Chris07LB's Avatar
My pedals from Ken@Sparks.
This post should answer your install questions... -
http://www.yarisworld.com/forums/showthread.php?t=1109
Old 09-08-2006, 11:15 PM   #18
Jfoofoo
Jfoofoo's Avatar
Drives: 07 Yaris HB Meteorite Metallic
Ooer Chris I just ordered mine from Ken at Sparks alone with few other items. Thanks for directing us to Sparks.
Just got e mail from Josh.. all my items has been shipped.. these guy sure do move fast.
Jfoofoo is offline   Reply With Quote
OBX PEDALS ARRIVED!!! jcove Cosmetic Modifications (Exterior/Interior) 24 06-19-2006 07:52 PM
