When was the last time you check that neglected spare tire under the floor in the trunk? I see mine on a regular basis but never think to check the pressure in it. So one day I had the floor out and happened to be checking and topping up all the rest of the tires in the family fleet and thought I should probably check that spare air.
It only had 10lbs in it. I think that was the 2nd time I've ever checked it in 11 years. So I blew it up to 60 as marked on the tire. Because it would really suck if you went through all the trouble of changing a tire on the side of the road only to have you spare flat too. |
| Tags |
| spare tire |
| Best tire pressure for Fuel Economy | edmscan | Fuel Economy Forum | 28 | 12-05-2012 11:55 PM |
| Spare tire question...................... | NEexpat | General Yaris / Vitz Discussion | 9 | 08-23-2012 08:29 PM |
| tire pressure | walt101786 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 03-01-2011 05:20 PM |
| tire pressure light goes on and off, on and off | janices_yaris | DIY / Maintenance / Service | 8 | 07-30-2010 04:58 AM |
