Old 01-10-2011, 01:49 PM   #1
walt101786
Drives: 07 Toyota Yaris Hatch-Back
tire pressure
hey guys, just a few simple question on tire pressure, I am currently running stock rims and tire, which I believe I still got like roughly 5k left. So my question is how much psi I should have. I am current running on about 37-40 psi. If I put 32 psi, I feel like my steering is heavy. So is 37-40psi too much and if it is how low should I go to. I am leaning dropping to 35psi. So any suggestions? Thanks
walt101786 is offline   Reply With Quote
Old 01-10-2011, 01:59 PM   #2
33OH
Drives: '08 Yaris
Why are you considering dropping pressure (what are you trying to achieve?)
Old 01-10-2011, 02:20 PM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
i run about what your running on my steelies.. 38-40. and rotating every 5k with oil changes. keeps the tires wearing out pretty evenly.. also good gas milage
Old 01-10-2011, 06:12 PM   #4
walt101786
Is it too high for what I have now? I'm running on like 37-40 so Iunno if it's ok to have it that high cus I heard the average is 32
Old 01-10-2011, 06:20 PM   #5
SailDesign
Drives: .
37 to 40 is fine. Don't mess with it.
Old 03-01-2011, 04:20 PM   #6
HerYarisNotMine
Drives: '07 Yaris Hatchback
Higher pressures like that will result in stiffer sidewalls...that helps handling, but will cause premature wear on the center of your treads...also, your tires are part of your cushioning and suspension system, so if you make them stiffer, you are transferring shock to your suspension system, which increases wear on it.
Everything is a trade off. If you car is a toy, sure, do any mods you want to increase your pleasure in driving it. But if it's a daily driver, I would follow factory specs for tire pressure. The extra MPG you massage out of it imo isn't worth the reduced traction and additional wear to the suspension.
HerYarisNotMine is offline   Reply With Quote
Single Tire Replacement - Using Pressure Sensor? 1stOne Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-13-2010 10:25 AM
recurring loss of tire pressure toad Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 12-10-2009 04:54 PM
Tire pressure sensors ztlonewolf DIY / Maintenance / Service 14 04-25-2009 05:19 PM
Higher Tire Pressure captainm27 General Yaris / Vitz Discussion 46 01-27-2009 10:17 AM
