![]() ![]() Drives: yaris 2005 Join Date: Mar 2016
Front WIndshield washer pump
Hi All,
I have checked the nozzle pipe its working apparently the front pump is not working. I have looked at the fuse 20A I think its for both front and rear. How can I access the pump it seems it is behind the front right tyre. Can anyone help pls how to easily access the pump for further investigation. Many thanks |
![]() ![]() Drives: yaris 2004 Join Date: Jul 2017
Quite easy. There are two pumps btw, one for the front and one for the back and both are attached to the water reservoir. Buy new ones on Ebay for around 5 euros each too.
The reservoir is on the right hand side looking from the rear. Jack up the car and take the front wheel off. Undo the studs that attach the wheel arch liner. You don't need to remove it all, just undo the ones near the front plus there is one underneath the front valance. You can then bend the liner sufficiently to get your hand in and access the pumps and the connectors. The liner is flexible and slotted into parts of the wing - bend it because it won't break. Remove pumps and replace. Simple. I have done it twice and it takes 20 minutes |
I do believe Haynes talks about removing the headlight - don't
Excellent Gents
Just to clarify do i need to remove the wheel or not. I have looked at the wheel there are m10 plastic fastners and m6 screws at the plastic arch. Sent from my SM-G930F using Tapatalk |
Thanks Gents
Are there any videos manuals |
Gents
Thanks for the responses I have managed to access the pump from front wheel turn clean the nozzles motor checked. Its all working like a charm. Sent from my SM-G930F using Tapatalk |
| Inexpensive fix for low windshield washer fluid light stiuck on | Toolaholic | DIY / Maintenance / Service | 5 | 04-21-2020 02:46 PM |
| FS Palmdale,CA: Floor mats, windshield washer, hubcaps, vvti cover, hatch container | AGlobalThreat | Items for Sale by private party | 15 | 08-19-2013 12:34 PM |
| 2012 Yaris LE Windshield Washer | joe_cur | General Yaris / Vitz Discussion | 6 | 03-01-2013 01:59 PM |
| 2012 Nissan Versa | Kal-El | Off-topic / Other Cars / Everything else Discussions | 22 | 06-15-2012 04:48 PM |
| Tinting front windshield | Dylanby | Cosmetic Modifications (Exterior/Interior) | 34 | 11-25-2006 03:03 AM |
