Old 02-23-2013, 05:13 AM   #1
joe_cur
Drives: 2012 Yaris LE
2012 Yaris LE Windshield Washer
Good morning,
I am new to YarisWorld and just want to say that this forum is an amazing source of information.
My 2012 LE hatchback does not appear to have a very effective windshield washer jet system. Passenger side windshield does not get cleaned very well.
Has any other 2012 owner experienced this problem?
Thanks.
joe_cur is offline   Reply With Quote
Old 02-23-2013, 06:32 PM   #2
muffin_top
Drives: 2012 Yaris SE 5MT
Yes, it just doesn't have much thrust from the nozzle. Its kinda like its supposed to ride down the wiper blade to the right but just can't quite make it. If you let the washer run for 10 seconds or so it works..
muffin_top is offline   Reply With Quote
Old 02-23-2013, 10:17 PM   #3
joe_cur
Thanks, I will give your suggestion a try.
Old 02-24-2013, 03:55 AM   #4
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I've always wondered if the system is correct on my 08 as there is just a mist that erupts from the base of the wiper but no direct water jet to the window.
Have Yaris will travel..
Old 03-01-2013, 12:02 PM   #5
joe_cur
I tried adjusting the spray nozzle with a pin. There appears to be enough pressure as the spray goes well beyond the windshield. I need to do a bit of tweaking to get the stream to cover enough of the entire windshield.
Old 03-01-2013, 12:37 PM   #6
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
Theres a small screen in the reservoir that will need cleaning from time to time.
If you use the anti freeze type washer fluid, it will get gummed pretty fast.
UberSilver is offline   Reply With Quote
Old 03-01-2013, 01:59 PM   #7
jambo101
jambo101's Avatar
Its been operating this way since the day i bought the car, i thought it to be a new way to wash the window however i will ask the dealer next time i'm there.
Yaris 2009 vs 2012 steinway General Yaris / Vitz Discussion 5 09-27-2012 05:21 PM
No ''S'' option for 2012 Yaris TRDMarty General Yaris / Vitz Discussion 15 03-29-2012 07:48 PM
