My Box and Her Egg
Drives: 05' Scion xB / 08' Yaris 3dr Join Date: Sep 2006
Easy mod for 5 spd. LBs starting/shifting.
I always hated how you had to push the clutch ALL the way to the floor to start it. I came up with a cheap easy fix for this issue.
I took a small 1" square piece of high dense foam (the kind that has smooth finish on the outside) and using some red 3M molding tape attatched it to the tab on the clutch lever where it contacts the switch. It gives enough so if you do push it to the floor it won't restrict pedal movement but contacts the switch earlier making it easier to start. I also adjusted the push rod so the clutch doesn't grab so close to the floor. It takes a 14mm and 13mm wrench and some small vise grips. Use the 14mm wrench to hold the switch and the 13mm to loosen the locknut. With the locknut loose you can unscrew the pushrod 1 1/2 turns (making it slightly longer). I used visegrip to turn the rod cause it was kinda hard to do it by hand. Then retighten the locknut and you are done. The clutch now grabs later and shifts much easier and more normal. |
| Quick, Easy and Cheap mod | bB2NER | Cosmetic Modifications (Exterior/Interior) | 11 | 03-06-2011 11:55 PM |
| Rim Weights | bosbik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 11-14-2009 06:42 PM |
| Engine Pull | Anthony_kp61dotnet | Performance Modifications | 12 | 03-11-2009 07:13 PM |
| manual transmission: to mod or not to mod? | tomato | General Yaris / Vitz Discussion | 34 | 03-08-2009 10:40 AM |
