Old 03-06-2011, 02:41 PM   #1
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Vacuum
What's your vacuum at idle? Just want to see what every one else has.
Old 03-06-2011, 02:43 PM   #2
Hmmm, I'll have to check tomorrow.
Old 03-06-2011, 03:51 PM   #3
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
-21 inhg on a warm day
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 03-06-2011, 05:17 PM   #4
cdydjded
Drives: Yaris LB Turbo
+/- 15-17. You do realize only people who are boosted will have a gauge to tell you this info. Im pretty sure very few if any who are not boosted run a vacuum guage.
Old 03-06-2011, 06:23 PM   #5
^ Pretty sure that's why he posted in the Forced Induction forum.
Old 03-06-2011, 07:04 PM   #6
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
yup
Ptuning.com
Old 03-06-2011, 07:36 PM   #7
-17
Old 03-07-2011, 07:20 AM   #8
johnny_vitz
Drives: 2005 Toyota Echo
15-17 on start-up...20-21 once its warmed up
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 03-07-2011, 03:01 PM   #9
Yoda
Yoda's Avatar
Ok thanks I ordered a new boost gauge and just wanted to see what I should be expecting in vacuum. Previous gauge did not have that.
Old 03-07-2011, 09:24 PM   #10
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
some things which can affect vac reading at idle... electrical load, afr's, and aftermarket cams. a stock, healthy motor is about -20 inhg. If you see -17 warm with ac off and proper afr... do a leakdown test.
Ptuning.com
Old 03-07-2011, 11:18 PM   #11
That's normal on my car.
Old 03-08-2011, 07:13 PM   #12
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
strange, maybe your intake manifold has something to do with that. Last time I had vac that weak my piston ringland was cracked.
Ptuning.com
Old 03-08-2011, 11:44 AM   #13
Yoda
Yoda's Avatar
mine is about -23 inhg but still trying to figure out why my idle afr is soo lean. I am making a boost leak tester right now to see if i have a leak. And also my idle is rough bouncing all over the darn place 300-1000rpm.
Old 03-08-2011, 07:15 PM   #14
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
sounds llike a flakey primary o2, or exhaust leak before it.
Ptuning.com
Old 03-11-2011, 09:02 PM   #15
Yoda
Yoda's Avatar
need alittle help. Is there another spot i can tee into for my new BOV? I want it to have its own vacuum/boost source. I am currently running everything off the intake manifold.
Old 03-15-2011, 06:24 PM   #16
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
I had the same problem with the lean, bouncing idle condition. Some times it would even die out. I think the 02 sensor gets much hotter when located so close to the turbo. Also with the o2 sensor connected it will always be fighting the FIC and trying to correct. Now I only tune with the o2s dissconnected. My idle is still a little lean but much smoother and no die outs.
pimp my yaris is offline   Reply With Quote
Old 03-15-2011, 06:38 PM   #17
I put in a vacuum block, it makes it easy and very secure for multiple boost/vacuum lines.
I thought Golden Eagle made them, but I can't find it on their site.
Here is one from Full-Race:
Old 03-16-2011, 10:42 PM   #18
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I found some.... hehe....... http://www.ptuning.com/html/Item-Des...niversal%20Fit
Ptuning.com
Whistle at idle - vacuum leak, induction side RichieRoo General Yaris / Vitz Discussion 17 12-16-2022 05:53 AM
How many MPB (miles per bar)? otterhere Fuel Economy Forum 56 07-15-2009 04:55 PM
Where is are all the vacuum hoses sourced? LtNoogie Performance Modifications 1 05-17-2009 04:22 PM
Vacuum Gauge vs. MPG turboecho2005 Fuel Economy Forum 8 10-29-2008 09:20 AM
