Old 02-10-2009, 10:29 AM   #1
otterhere
Drives: 2008 Yaris 3-door Meteorite
How many MPB (miles per bar)?
Seems to me that I get lots of miles with my first bar, a little fewer with the next, and so on until those last few bars before the last one starts blinking for a fill-up go sluuuuuurp, GONE! You, too?
Also, since inflating my tires to the CORRECT pressure, I'm so far doing much better on my first bar; over 60 miles this tank, and still it hasn't disappeared.
otterhere is offline   Reply With Quote
Old 02-10-2009, 10:58 AM   #2
33OH
Drives: '08 Yaris
If you're like me and keep fueling even AFTER the gas pumper clicks that its full, yeah you'll get more miles on that first bar.
Old 02-10-2009, 11:13 AM   #3
smacky
Drives: 2008 Liftback AT
I only fill up until the click and the same thing happens to me. I generally get around 80 on the first bar and it decreases a bit for each bar until it is a bit lower than 50 for the last couple bars. But it's never very consistant. The bars aren't a very precise indicator of fuel used or miles per gallon.
smacky is offline   Reply With Quote
Old 02-10-2009, 11:38 AM   #4
33OH
Drives: '08 Yaris
Yeah very true. I didn't mean it like it won't happen unless you go past the click, I just mean I always do and then you REALLY notice it.
Old 02-10-2009, 12:08 PM   #5
otterhere
80 miles on the first bar? Highway or city? Dang; I thought I was doing well with 60... Now I'm depressed again...
Old 02-10-2009, 12:48 PM   #6
PreciousPups4U
I really LOVE this car!!!
PreciousPups4U's Avatar
Drives: 08 Bayou Blue LB AT
Same here close to 75 - 80 on the first bar. Then somewhere between 40 - 50 on the rest of the bars. Three bars is about half the tank and then the other five bars are the last half of the tank or at least that's how it seems to work for me.
Mine is pretty much all city driving.
Cindy
Old 02-10-2009, 12:49 PM   #7
PreciousPups4U
Yours is still pretty new. Give it some time. Depends on lots of things, too. Like terrain and how close traffic lights are together and such.
Cindy
Old 02-10-2009, 02:07 PM   #8
Havana
Havana's Avatar
Drives: 2009 Yaris 3 door M/T
I hate those bars. I've gotten over 90 miles on the first bar and as little as 15 on the second to last bar. To me, it's almost useless as a fuel gauge. How can it show around 300 miles travelled at "half a tank" and only get around 85 more miles from the other "half." Answer: 50% of the bars gone does not indicate half a tank used or left. All that gauge tells is that I have some gas more or less.
Havana is offline   Reply With Quote
Old 02-10-2009, 02:54 PM   #9
Split
Drives: 2008 Yaris Sedan
its so inaccurate.. the first bar is like half the tank.
Split is offline   Reply With Quote
Old 02-10-2009, 04:00 PM   #10
nemelek
DWEED
nemelek's Avatar
I get 75-80 on the first bar. Most cars that I have owned are inaccurate. I use well over 1/2 a tank by the time the gauge hits the mid point.
Old 02-10-2009, 04:20 PM   #11
smacky
I'm usually driving about 75% highway, that helps a lot. But my first bar is sometomes around 65 miles but my scangauge doesn't reflect FE that's too much lower. The bars are not accurate. Get a scangauge if you can, I think it's money well spent.
Old 02-10-2009, 05:47 PM   #12
1stToyota
1stToyota's Avatar
It's about as accurate as it can be, seeing that it's pretty hard to find a car with a perfectly square tank...maybe a '69 Chevelle with a fuel cell mounted in the trunk.
I can usually go 100 miles before I hit 7/8ths, about 300 miles before I hit 3/8ths.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 02-10-2009, 06:00 PM   #13
otterhere
Seems you should be able to do the math: first bar's mileage times 7 (bars) divided by 10 (gallon tank), but that doesn't work, or I'm just bad at math.
Old 02-10-2009, 06:55 PM   #14
1stToyota
1stToyota's Avatar
Or Toyota isn't going to get excited enough about the Yaris fuel tank and dash cluster to factor in float drop vs tank shape? When it's full I know I got a long ways to go, when I'm down to 1/4 I start huntin for gas pumps.
2008 Scion xD
Old 02-10-2009, 07:21 PM   #15
Forrest
Drives: 08 LB BLACK
There is a warning on the gas cap not to try and fill once a pump has clicked off. Something about check engine light may come on.
Also, bars are a rough indication of gas usage, but not totally accurate.
Forrest is offline   Reply With Quote
Old 02-10-2009, 07:28 PM   #16
1stToyota
1stToyota's Avatar
My cap says tighten 1-click or check engine light may come on; EVAP leak.
2008 Scion xD
Old 02-10-2009, 07:40 PM   #17
Krusher
Drives: 08 Sedan
The reason for not overfilling the tank after the auto-shutoff is due to getting liquid into your EVAP canister(s)... Those are expensive and only suppose to see vapor... but it's like a 10% chance you'll end up screwing the canister up one fill-up... not a big risk and you won't see it happen very often.
I don't fill beyond the auto-shutoff....
Krusher is offline   Reply With Quote
Old 02-10-2009, 11:42 PM   #18
firebird1999us
firebird1999us's Avatar
Drives: 2003 Mach 1
About 80 on the first bar, 70 second, and about 60 for the next few. I'm at the bar that tops out right at half a tank and I've went about 250+ miles so far...about 90% highway
firebird1999us is offline   Reply With Quote
2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. trini_per4mance General Yaris / Vitz Discussion 100 06-08-2022 10:54 PM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 07:52 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-06-2008 12:37 AM
Synthetic Oil Kaotic Lazagna DIY / Maintenance / Service 122 09-20-2007 04:40 PM
c one motorsport performance bars badhabitz Performance Modifications 17 08-23-2006 11:31 PM
