Old 04-24-2007, 10:36 PM   #1
Ogredude
Ogredude's Avatar
Drives: 2007 Red Yaris RS
$30 Oil Catch Can, DIY
who needs a Cusco, keep your intake clean with an air compressor filter / air dryer,
parts needed:
$26 - 3/8" Husky filter (crappy tire / walmart)
$4 - 3/8" hose fitting connectors
and some teflon tape
after only 500km it has about a teaspoon of oil caught already, crazy eh?
here is a corvette owner who has also done this:
http://forums.corvetteforum.com/show...4&forum_id=103
1. Take off engine cover - 4x10mm nuts
2. You have to cut the PCV hose, the one that goes from the back of the vavle cover into the intake manifold near the front. Cut the hose about 4" down from the back, and re-install it the opposite way, now there is room for the compressor filter away from the motor.
3. Install the Hose fitting connectors into each side of the compressor filter, with the teflon tape,
4. install filter. Make sure it is facing the right direction, the air flows down from the valve cover and gets sucked into the intake so the arrows on the compressor filter should be the same direction.
5. The valve cover Intake hose will have to be removed for the install, and be re-installed over top of the exit hose.
Hope you can understand that Jumble, these pics should help a lot.
Ogredude is offline   Reply With Quote
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Synthetic Oil Kaotic Lazagna DIY / Maintenance / Service 122 09-20-2007 03:40 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 02:56 AM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
