Old 11-16-2011, 11:24 PM   #1
salmonz
salmonz's Avatar
Drives: 07 Yaris Sedan
Drum brake thumping
So I changed the rear shoes in my 07 Yaris Sedan with aftermarket shoes and new spring hardware but kept the original factory drums on, bled the brakes, now I'm having a thumping noise when applying the brake at 40km/hr or less. I feel it through the pedal but it's definitely coming from the rear.
Here's what I've done to try to fix the problem but didn't work:
1. Stretched the hold down springs to put more pressure on the shoes.
2. Made sure the self adjuster was sitting correctly.
3. Made sure the shoes and the drum were snug enough that there isn't any major gaps between the drums and shoes.
4. Lubed the adjuster, lubed contact points on backing plate.
5. Checked for wheel bearing play - none.
6. Checked for debris, i.e. rocks - none.
7. Checked all springs for tension and that everything was sitting properly.
8. Checked wheel cylinder for leaks - none.
What I'm thinking of doing (in order):
1. Replacing hardware with factory hardware.
2. Replacing drums.
What may be causing this and how do I fix it?
salmonz is offline   Reply With Quote
Old 11-17-2011, 01:37 AM   #2
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
The only time I've ever had thumping from drum brakes is when I've warped one.
Turn the drum and slowly adjust the brake out until you get just a little bit of drag. Turn the drum and see if the drag is constant or the drum moves freely then drags or moves with a little drag then grabs.
If the slight drag isn't constant, check to see if the drum is clean on the inside, brake fluid spills inside the drum will cause different friction when rotating them. If everything is clean and the drum and brake hardware are mounted properly, it's most likely a warped drum.
Check both sides, if both turn with a constant amount of drag I'd guess it has to your aftermarket parts.
Stove is offline   Reply With Quote
Old 11-22-2011, 01:30 AM   #3
salmonz
salmonz's Avatar
Thanks!
The thump is actually a knocking noise.
I'm buying new drums this week and will see how that goes.
Old 11-22-2011, 07:13 PM   #4
salmonz
salmonz's Avatar
New drums - fixed problem
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
rear brake drum parts yv1650c DIY / Maintenance / Service 0 09-26-2010 11:08 PM
Drum brake upgrade xbalance Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 04-19-2009 05:16 AM
