Old 04-14-2009, 06:42 AM   #1
xbalance
Drives: stock
Drum brake upgrade
Hi guys, Is it posible to convert Drum brake to Disc brake sistem?
xbalance is offline   Reply With Quote
Old 04-14-2009, 07:10 AM   #2
ruimond
Drives: Yaris YR
If your talking about the Yaris Rear Drum Brakes, yes they can be converted into a Rear Disc brake system. You can buy the kit from Microimage Shop.
Link: http://shop.microimageonline.com/pro...=3&productId=7
Hope that helps.
Old 04-14-2009, 04:05 PM   #3
Brian
Brian's Avatar
I did the rear disc brake conversion
Old 04-14-2009, 04:20 PM   #4
fuji
fuji's Avatar
Drives: Polar White Yaris HB
How much of a difference did it make in your braking?
fuji is offline   Reply With Quote
Old 04-14-2009, 04:21 PM   #5
fuji
fuji's Avatar
Another thought is instead of upgrading to discs is to do what we can to optimize the performance of the drums. Any thoughts???
Old 04-14-2009, 04:51 PM   #6
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Generally the rear brakes only account for about 30% of your braking power. Any changes you make need to be balanced with the front brakes or the rear wheels will lock up and lengthen your stopping distance. (Assuming you don't have ABS.)
Disc brakes are harder to use with a parking brake. Most cars with 4-wheel discs have an auxiliary parking brake drum.
Old 04-14-2009, 06:19 PM   #7
firebob
Drives: 09 yaris
They do make calipers that have a lever that pushes the pads together for the parking break but it’s been used on few cars and still dose not have all the bugs worked out yet. I’m sure one of the manufactures will start using it soon and will be a new problem for the masses. At one point one manufacture will out way the issue of fewer parts to build into a car to the issue of fixing them under warranty…
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week.
firebob is offline   Reply With Quote
Old 04-14-2009, 06:51 PM   #8
If you want to keep your drums but upgrade performance, order custom shoes (from me, of course) with CarboTech material to improve bite and grab, plus stainless lines and better fluid.
Otherwise, our rear disc conversion is very good. I've been using it on both track and street for several months with no problems.
Old 04-14-2009, 07:49 PM   #9
xbalance
Drives: stock
If i park my car at the slope area will parking brake will the car roll down?
Old 04-16-2009, 10:01 PM   #10
xbalance
Drives: stock
by the way is your rear disc brake ABS & EBD working? or just normal disc brake function?
Old 04-17-2009, 03:28 PM   #11
fuji
fuji's Avatar
Like discs, do drums need to be resurfaced if you are putting in new drum brake pads? The stainless lines sound like a good idea as well.
Old 04-17-2009, 04:23 PM   #12
Yaris Hilton
Smile
Drums typically are turned when the shoes are replaced. Lately my shop has found new Chinese disks and drums for most cars that cost little more than turning them, so they usually just get replaced with new ones.
Old 04-19-2009, 03:34 AM   #13
fuji
fuji's Avatar
Any other options for drum brake pads with great bit that are not dusty???
Old 04-19-2009, 05:16 AM   #14
Yaris Hilton
Smile
Dust is what you get when brake linings wear.
DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads ChinoCharles DIY / Maintenance / Service 40 10-13-2017 05:23 PM
BIG(GER)TM BRAKE KIT Vanderkitten Performance Modifications 23 01-04-2009 07:16 PM
