Old 12-12-2011, 02:44 PM   #1
A-Dingo-Ate-My-Baby
Drives: yaris
Torque wrench on lugs is critical on the Yaris
critical, because over-tight can induce warping as I found
I had slapped on my winter rims with 'pretty dang tight' and no torque wrench,
and all is fine and everything seemed OK.
a little bit when braking, I felt a thumping...Oh no....warped rotors...no way
did I overheat these things....I mean...really ????
anyhow, finally I dug out the digital torque wrench and retorqued all
my bolts to 76 foot pounds.
a) I found my human-gorilla torque was around 84/88/91/80 about average for all my lugs, but one front was 97 !!!!
b) after retorque to specs, Yaris is smooth as butter when braking
c) gorilla-tech method is always fine for my 4runner, but that thing has
much bigger rotors.
conclusion: you change tires on this little Yaris, torque wrench really is
a requirement. 'Just freaking tight' is going to be overkill on weeny rotors
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 12-12-2011, 04:10 PM   #2
RedRide
RedRide's Avatar
You have to be careful to tighen the nuts properly no matter if you use a torque wrench or not.
Old 12-12-2011, 04:21 PM   #3
A-Dingo-Ate-My-Baby
Drives: yaris
well I did do it 'properly', but overtorqued one 'cuz I didn't have a
tool to measure, other than 'gumption
properly means use a torque wrench, so this statement doesn't make sense
Old 12-13-2011, 06:33 AM   #4
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
"Properly" as in "tightening the lugs in the correct sequence." (Not saying you did it wrong, just pointing that out.)
Persuade me to buy a Yaris! TONIZZLE General Yaris / Vitz Discussion 48 09-09-2011 11:31 AM
