![]() Join Date: May 2015
CEL eliminator
Need some advice... planning on installing the OBX cat back exhaust system on my 2014 yaris. Problem is, it's more than just a cat back. It deletes the resonator and both cats. Should I use Weapon-R's cel eliminator?
Sent from my SM-N920P using Tapatalk |
#2 | |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
It's not street legal as is only intended for the track. |
Drives: meteorite metal 07 Hatch Join Date: Apr 2015
i have the OBX on as well. i used the blox CEL eliminator off of amazon. around 2000 miles now with no light. im putting a magnaflow cat on like rigaud said he did, but my cats going where the muffler is so i had to elimate the CEL light whether i put a cat on or not.
#4 | |
Plus over here if I did that it would be considered like not having a cat and instant ticket. |
#5 | |
Im hoping I dont get a ticket for it, as it is my DD until I get it complete which wont be until late spring or summer of next year. the cost would just slow down the progress of my build |
#6 | |
Sent from my SM-N920P using Tapatalk Last edited by tykeeler; 10-23-2015 at 01:32 PM. |
Question guys.... I cannot get the bolts (spring loaded) from the axle-back to come off...
are they stripped or just stuck?
If they're stuck then spray the crap out of them every 15 mins for a couple hours with something like pb blaster and then try. If they're stripped then spray the crap out of them and then use a bolt off socket (it worked for my stuck header gasket bolts). Some people have had to use heat to remove them. worst case, drop the mid pipe and cut the bolts off and then drill out the part still stuck in the threads. When you re install always use anti seize on exhaust components. If you likve in the salt belt like I di every few years I'd recommend removing the bolts re applying antiseize and re installing them.
It's a 2014 so it's not like they're old... it's just stuck.
A bolt is only "stuck" because you aren't using enough force to break it (unless it's self welded but it's only a 2014) Use a breaker bar or better yet air tools. You'll thank yourself for work you do down the road.
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
As the saying goes:
"If it's jammed, force it! If it breaks...it probably needed to be replaced anyway." Sent from my SM-G925W8 using Tapatalk
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
| CEL afer oil pressure light | andysong | DIY / Maintenance / Service | 8 | 03-06-2020 02:57 PM |
| Help! CEL P0420 | kwkshft | DIY / Maintenance / Service | 10 | 03-15-2014 09:10 PM |
| AFE Intake cel | rihdrkc | Performance Modifications | 11 | 01-09-2012 03:23 PM |
| CEL thrown for temporarily disconnecting things | jmjonesey | DIY / Maintenance / Service | 2 | 06-28-2010 02:38 PM |
| FS: Sedan Nitto Mid-Pipe w/ CEL Fix | Split | Items for Sale by private party | 37 | 12-18-2008 12:11 PM |
