Old 05-03-2010, 10:33 PM   #1
rihdrkc
Blazing Blue Yaris
rihdrkc's Avatar
Drives: 2009 Yaris 3 door Liftback
AFE Intake cel
Recently installed an AFE intake. CEL came on after about 100 miles. Disconnected battery and cel went away for another 100 miles. Had code checked and came up with p0101 MAF sensor failure. Codes were cleared then cel came back on after about 30 miles. Have checked previous posts. Not many have posted if they fixed this.Any suggestions? Hoses are tight and the MAF is tight and appears to be seated properly.
http://www.yariscentral.com/index.php
Just an old guy rockin it with you young-uns
rihdrkc is offline   Reply With Quote
Old 05-03-2010, 11:13 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
possible that you damaged the MAF sensor during the installation? Have you tried the DIY on how to clean the MAF sensor?
Old 05-03-2010, 11:16 PM   #3
rihdrkc
Blazing Blue Yaris
rihdrkc's Avatar
I was extremely careful with maf and it looks clean
Old 08-20-2010, 11:26 PM   #4
j2ip
Drives: Yaris Sedan 2008
Question
I am having a same problem did you fix it yet?
j2ip is offline   Reply With Quote
Old 08-20-2010, 11:45 PM   #5
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
spray it w/ maf cleaner
Red Horse is offline   Reply With Quote
Old 08-21-2010, 12:01 AM   #6
rihdrkc
Blazing Blue Yaris
rihdrkc's Avatar
The problem I was having was caused by the spacers under the MAF sensor. I installed the MAF without the spacers and that cured the problem. You just have to be very careful and not over tighten the screws.
Old 08-21-2010, 12:04 AM   #7
Red Horse
Red Horse's Avatar
Mine does'nt have a spacer to begin with, even w/ the stock intake.
Old 08-21-2010, 12:11 AM   #8
rihdrkc
Blazing Blue Yaris
rihdrkc's Avatar
AFE supplies spacers to put under the maf screws to prevent people from over tightening them and pulling the threaded inserts out of the intake
Old 08-22-2010, 10:24 PM   #9
severous01
did you use the foam seal on the maf that came with the kit? you may want to get some 1/4" thick foam and cut a new gasket. my bolts came out (the nut part in the plastic came loose). i have to zip tie my maf down against the seal.
Old 08-22-2010, 11:51 PM   #10
rihdrkc
Blazing Blue Yaris
rihdrkc's Avatar
yes I used afe's foam gasket. I called the factory and talked to them. Removing the spacers was their suggestion. You have to be very careful not to over tighten the screws
Old 08-27-2010, 02:46 AM   #11
j2ip
Thumbs up
What I found is the screws that they supplied was too long. I replaced the shorter screws and took out the spacers for a week now. It does not find P0101 any more. Thanks rihdrkc.
Old 01-09-2012, 04:23 PM   #12
randydid
Drives: 2012 Yaris SE Five Door
aFe on a 12 SE
I just put the aFe intake on my 2012 SE. The heat shield fits OK-you just need to bend it a bit but it clears the hood, etc. Also, there is a vaccumm hose mount on my '12 that is not included in the aFe tube. I just zip tied it out of the way.
On topic, I got the P0101 CEL code and someone kindly pointed me to this thread. Glad YW forums are here! Great resource!
/randy
randydid is offline   Reply With Quote
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 03:03 PM
AFE Intake and NST 10% UD Pulley Gray hatchbackkid82 Items for Sale by private party 12 04-17-2010 10:16 PM
Garm's AFE intake vs. TRD high flow air filter???? computerlove87 Performance Modifications 28 07-22-2009 06:05 PM
Afe intake installed...CEL ??? vten Performance Modifications 7 06-05-2009 01:08 AM
Intake Systems Decision Maker.. Blenjar Performance Modifications 25 09-15-2007 11:07 PM
