Old 08-10-2015, 11:35 AM   #1
shepd
Drives: 2007 Yaris 5 door RS
strut bolts
I recently removed the strut bolts to get at the steering knuckle. They were BEYOND difficult. The nuts appear extremely galled and do not fit back together to the bolts well at all.
Should I replace the parts? I would normally when they're this messed up. I assume I can't just use any high grade bolts that fits nicely? I believe the top one sets the camber, and the bottom one should pretty much be there to hold the parts together?
No, I'm not doing my own alignment, but once I bolt everything back together, I'll need it safe so it can make it straight to the alignment shop. :)
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
Does Toyota put loctite red on the rear strut bolts?? DeathBeard General Yaris / Vitz Discussion 16 05-07-2012 02:27 PM
