Old 04-20-2012, 01:14 PM   #1
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
Does Toyota put loctite red on the rear strut bolts??
Hey all,
was installing my tein springs..the front was cake, the rear has been a nightmare, in fact broke two craftsman socket wrenches trying to remove the rear lower strut bolts! My 08 was easy to remove, these seem like they are seized or they have loctite red on them anyone else experience this? I have a 15" 1/2 breaker bar with 14mm socket that won't fit where I need it to thanks to the rear drum assembly
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 04-20-2012, 01:40 PM   #2
enviri
enviri's Avatar
Drives: 2010 Yaris
I swapped suspensions on an 08 and 2010 yaris, along with an 09 xd and the rear bolts came off like nothing..maybe jack up the drum so there's less stress on the bolt? Possibly loosen up the bolt before jacking the rear end, assuming you're still at the oem 4x4 height.
Old 04-20-2012, 01:42 PM   #3
DeathBeard
DeathBeard's Avatar
man I did it all and this thing will not move! sucks, this bolt has turned all my tools into it's bitch
Proverbs 16:9
Old 04-20-2012, 01:45 PM   #4
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Just the opposite. Installing springs on the rear was far easier. Had no issue with the bolts. Sure your perspective isn't off and you've actually been trying to tighten them? Never hurts to ask.
Old 04-20-2012, 01:46 PM   #5
DeathBeard
DeathBeard's Avatar
lefty loosey righty tighty right
Proverbs 16:9
Old 04-20-2012, 01:48 PM   #6
Put a torch to the nut. A little heat can go a long way.
Old 04-20-2012, 02:09 PM   #7
DeathBeard
DeathBeard's Avatar
already tried that this bolt has turned fire into it's bitch
Proverbs 16:9
Old 04-20-2012, 02:12 PM   #8
electric impact wrench ftmfw!
I don't understand why you can't get your breaker bar & socket to clear the drum.
Old 04-20-2012, 02:14 PM   #9
Spidermandud
Spidermandud's Avatar
Drives: Black '08 Yaris Hatch S
Beat it with a hammer and throw some wd-40 on there.
-Will-
Spidermandud is offline   Reply With Quote
Old 04-20-2012, 03:48 PM   #10
Altitude
Altitude's Avatar
Cut 'dem bitches off with a torch!
Old 04-20-2012, 05:27 PM   #11
RedRide
RedRide's Avatar
I'm not saying that the OP did no know this but, I'm always amazed at the grown men who actually do not know this..... either at my former job (now retired) or, in my day to day encounters
Personally, my dad instructed me on this when I was about 3 years old.
Old 04-20-2012, 05:29 PM   #12
DeathBeard
DeathBeard's Avatar
got the bolt off! Sprayed it with Liquid Wrench, waited 10 minutes and voila!
Proverbs 16:9
Old 04-20-2012, 05:50 PM   #13
Altitude
Altitude's Avatar
Old 04-20-2012, 05:54 PM   #14
Stupid me. I'd assumed you'd already hit it with some product.
Old 05-07-2012, 12:45 PM   #15
YarisSedan
Drives: 08 Yaris Sedan
Unless your working on british cars the lugnuts on left side are removed turning left and right side are removed turning right.
Old 05-07-2012, 02:11 PM   #16
vten
Had the same Problem before . Lucky you can take them out ... On my case I had to bring the car to a local shop and they need to cut them with an air saw ... 10 minutes and $300 later ... They put the new struts in .
Tried to argue with the shop " why I have to pay $300 for a 10 mins job ??" they said theyre just following the labor manual on those thing.... I was like F yu guys ... You just lost a returning customer ..
Old 05-07-2012, 02:27 PM   #17
yariSB86
yariSB86's Avatar
Drives: 07 Bayou Blue Yaris LB
OP -for future reference, always try to use an alloy socket. they are far stronger that that "stainless steal" looking crap. almost all impact tool sets come with alloy sockets. i learned the hard way also when removing the torx bolts holding down my back seat.
yariSB86 is offline   Reply With Quote
Need input on ULTRA RACING 23MM SWAY BAR VS NITTO REAR LOWER STRUT BRACE. marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 02-22-2011 07:32 PM
CAN TOYOTA RETROFIT NON-FIXED REAR WINDOW? pennsylvania girl Cosmetic Modifications (Exterior/Interior) 8 04-22-2007 01:47 AM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 03:16 AM
