Old 03-21-2012, 11:40 PM   #1
Ratz
Ratz's Avatar
Drives: 2011 Yaris 4 Dr. Sedan
Ultra Racing rear sway bar
Ultra Racing make 19mm and 23mm type. Not sure what size I should use for my 2011 Sedan. I do not want to make the car rough riding, as after all it is a Sedan driven gently.
Also, if there is a different brand (better) I would concider it.
Any input would be appreciated.
Ratz
Cleverly disguised as a responsible adult.
Ratz is offline   Reply With Quote
Old 03-22-2012, 12:49 AM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
The 19mm is just fine for street use with spirited driving
Old 03-22-2012, 03:43 AM   #3
yariseggvvti
Drives: Yaris Hatchieback
23mm,23mm,23mm. Rough riding only when you lower and replace the shocks. I got stock suspension but with all the Ultra racing bars. You will feel a big difference when you making a tight corner turn. Also,UR available rear stabilizer bar too.
yariseggvvti is offline   Reply With Quote
Old 03-22-2012, 11:16 AM   #4
RedRide
RedRide's Avatar
I got the 23mm for my DD and I love it .
Yes, it will stiffen the rear suspension a bit like either sway bar will but in a great way. You wiil no longer feel like you are driving a boat.
In any event, it can not in any way be considered harsh, or rough riding.....just balanced between the front and rear. Keep in mind that the Yaris already has a good stock front sway bar.
It has be said that one can not reallly feel the difference between the 19mm and the 23 mm until you reallly push the car and then, you can feel the benefits of the 23mm bar.
So, get either one from UR and you wiil not be disapointed!
Old 03-22-2012, 11:45 AM   #5
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
I have a 23mm on my sedan and couldnt imagine going smaller
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 04-12-2012, 05:19 PM   #6
These bars don't change handling in a straight line, they don't make the suspension stiffer that way, though the car will resist buffeting from winds and passing semis a LOT better.
Old 04-18-2012, 06:34 PM   #7
RedRide
RedRide's Avatar
Acutually, it did stop the wandering at highway speeds for me for what ever reason.
Also, when one thinks abouit it, unless both wheels are focrced up (by the road) by exacly the same amount every time, the suspension will feel a bit stiffer but, in a very postive way.
Old 04-18-2012, 08:40 PM   #8
Ratz
Ratz's Avatar
Thanks everyone looks like the 23mm is the one. Will order it tomorrow.
Ratz
Old 04-12-2012, 05:29 PM   #9
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
What about that Nitto Rear lower shock brace? Ive seen it in your store and am curious. What is the difference between that and the sway bar? Does it stiffen the dampening of the rear suspension? Or does it stiffen like a sway bar, side to side?
Old 04-12-2012, 06:03 PM   #10
The sway bar (actually a torsion bar with a beam rear axle like we have) resists twisting by transferring weight to the OPPOSITE FRONT corner. Preventing roll translates into more traction on the front inside tire.
The rear trailing arm brace (rear underbrace) boxes in the trailing arm - beam - trailing arm "U" shape, providing more stiffness, and resistance to deformation. The rear of the car feels "tighter" or "crisper" with this brace in place.
Old 04-12-2012, 06:26 PM   #11
randeez
Drives: 2008 3dr
from someone with the 19mm....
get the 23mm
I will probably upgrade mine at some point, the 19mm is a lot better then not having one by leaps and bounds, i can only imagine the 23mm is that much better with really no ill effects. i dont really drive hard, but i do still notice a little getting blown around, and i'm sure tires/rims will probably suffice for me since i'm still way up in the air with only an inch drop. however as slow as i go on the highways people wondering wtf i'm doing when i dont bother slowing down to get off an offramp is great
randeez is offline   Reply With Quote
Old 04-12-2012, 07:16 PM   #12
1.5
Form>Function
1.5's Avatar
I speed up for on ramps
Old 04-12-2012, 08:24 PM   #13
^ LOL, yeah that's the spirit!
Old 04-12-2012, 09:36 PM   #14
chewychewbacca
Drives: 08 Yaris S 3Dr
I went from 19mm to 23mm and it was a noticeable difference for me especially on the freeway...
chewychewbacca is offline   Reply With Quote
Old 04-12-2012, 10:03 PM   #15
randeez
Drives: 2008 3dr
yes, i hear my babysmama gasp everytime i wing it towards an offramp if shes with me.
Old 04-18-2012, 11:58 AM   #16
OH yaris
Drives: 07 hatchback + 06 EVO9
glad to see a consensus on the 23mm size... placing order shortly. thanks to all contributors. I'll update with my experience once it's on and driven around for a bit.
OH yaris is offline   Reply With Quote
Old 04-30-2012, 08:59 AM   #17
OH yaris
Part arrived on schedule but I didn't get around to the installation until this past weekend. The test drive was fun, definitely a noticeable reduction in roll around corners. If you are thinking about this upgrade, I cast my vote for yes, go for it!
Old 04-30-2012, 12:49 PM   #18
Ratz
Ratz's Avatar
I take it you purchased the 23mm Ultra Racing. Can you please post some pictures? I would like to see the fit as Ultra Racing bars do not use the two additional bushings like Whiteline does.
What counts is you are happy. Congratulations.
Ratz
TRD rear sway bar? Lewis DIY / Maintenance / Service 26 09-10-2013 02:10 PM
Yaris Rear Sway Bar Install ? Spork Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 03-20-2012 09:17 PM
My Ultra Racing rear sway bar install CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 49 03-03-2011 02:08 AM
WTB Rear Sway Bar nick.dollimount Willing to Buy by private party 2 05-27-2010 02:44 PM
rear sway bar needed vten Willing to Buy by private party 11 11-22-2009 11:50 PM
