Old 08-06-2017, 12:26 PM   #1
600RRgoal
Drives: Yaris
Want a full size spare
Hi all,
I drive my car a LOT on long distance 1,000+ mile trips and always wondered what I'd do if I blew a tire at 2:30 AM in the middle of nowhere on a Saturday night. That being said, I want a full size spare for these trips.
My Yaris is the first car I've owned that has TPMS. Aside from buying a steel wheel and a tire, what other components do I need? Do I need an actual TPMS sensor to keep the TPMS light from coming on the dash? Anything else?
Thanks guys.
600RRgoal is offline   Reply With Quote
Old 08-06-2017, 04:52 PM   #2
bronsin
bronsin's Avatar
Full size spare Will not fit where your doughnut spare goes. Yes you'll need a sensor for the steel wheel spare if you get one or the light will go on. I have steel wheel spares in the shed for both our cars But there's no way to carry one.
Old 08-06-2017, 06:56 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
You will have to sync the extra sensor with the car anyways. Spare don't need the sensor AFAIK.
Old 08-07-2017, 09:36 AM   #4
hotracer_05
Hmm, I see...
hotracer_05's Avatar
Drives: 2012 Toyota Tundra and Yaris
Do you have a hatchback or sedan? i was able to fit a full size spare in my hatchback
"Everything happens for a reason. Sometimes that reason is you're and idiot"
hotracer_05 is offline   Reply With Quote
Old 08-07-2017, 12:13 PM   #5
bronsin
bronsin's Avatar
And the cover fits flush?
Pretty sure my full size spare won't fit in there. Could I be wrong!?
Old 08-07-2017, 12:18 PM   #6
600RRgoal
Drives: Yaris
Thanks guys.
I have a hatchback and was planning on throwing the spare in the back. I always have the back seats folded down so there will be plenty of room.
Old 08-07-2017, 01:01 PM   #7
dogsridewith
Drives: 2007 2-door hatchback
There's a thread here w/ photos on removing the spot welded stamping that props up the front of the spare...I believe reason involved fitting a larger spare.
Old 08-07-2017, 02:51 PM   #8
hotracer_05
Hmm, I see...
Yeah you can fit a full spare
One of the original tires was in decent shape, and since i bought the car without a spare i decided to just use it (not a fan of doughnuts anyways). The full size tire wont fit where the old spare goes without removing the riser piece on the top. This is tac welded to the car, so before doing this you need to make sure you don't have any emotional attachments to that doughnut. I simple took a big hammer and beat it out...but you can definitely grind away the tac welds. then simply fill the holes in and ta da! full size spare room
Old 09-20-2017, 10:25 PM   #9
iA_b4_07HB
Drives: 2017 iA
Very impressive Hot Racer. I'm not sure I'd need another wheel, but carrying around a tire would certainly be great. Almost any service station can put on a new tire (after the towing) but almost no station is going to have that size tire.
On the other hand most flat tires are repairable.
The other part of me would take out the tire altogether, drop in an inflation kit, and enjoy the massive additional storage space.
Hidden storage space, at that. In San Francisco these days you have to leave or glove box open and take off the cargo cover or you get a broken window from junkies looking for anything at all to steal.
iA_b4_07HB is offline   Reply With Quote
Old 09-20-2017, 10:48 PM   #10
SirDigby
Drives: 2007 yaris 3 door
yeah, plate removes easy. inflation kits are super gross! don't use those!
October 16th Sunday 2-6pm, Shannonville Full Track event! 20th event of 2011!!! Touge.ca Canada 2 10-06-2011 12:07 AM
Exhaust Pipe Size (Tamaño del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
