Old 06-14-2012, 11:29 AM   #1
yariSB86
yariSB86's Avatar
Drives: 07 Bayou Blue Yaris LB
extra speakers ?
i have some questions about our factory stereo:
1. can the head unit support 2 extra speakers?
2. can i just splice my extra speakers into the currently wired rear speakers?
3. will i need more power? i.e. an amp?
my friend gave me his old 6x9s that he never used. each speaker is built into its own box. id like to leave the speakers in the boxes, if at all possible. i just dont know how to install them.
yariSB86 is offline   Reply With Quote
Old 06-14-2012, 11:59 AM   #2
yariSB86
yariSB86's Avatar
some photos of the speakers and where i would like to install them.
Old 06-14-2012, 12:07 PM   #3
09sedan
Drives: 2009 yaris sedan
You can.
A) get an aftermarket headunit, install a 4 channel amp, and power those speakers
B) unplug the rear speakers and solder extension speaker wire and run them to the speakers.
Option a will benefit you alot more cuz it will leave you room to upgrade your front speakers with components and hook up a subwoofer if you want extra bass, but it will involve more money since you need to invest in electrical sytem (wiring, new battery, possibly alternator if you want big power) option b is alot cheaper but severely limits you in terms of upgrade options,
09sedan is offline   Reply With Quote
Old 06-14-2012, 12:17 PM   #4
G-Ammo
G-Ammo's Avatar
Drives: Toyota Yaris 2009; 1.0 3 Cil.
Nice! I maybe wanna do this too :D Maybe ill try to put speakers in the original spots or in the trunk :)
G-Ammo is offline   Reply With Quote
Old 06-14-2012, 04:53 PM   #5
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Pull up Google and look up Impedance before you begin hooking up speakers.
Old 06-15-2012, 03:15 AM   #6
sqcomp
Roadrunner Jr.
sqcomp's Avatar
IIRC, all the stock speakers are 4 Ohm.
If you are going to use an amplifier, look for one that has high level inputs. Those will make your life easier (or should) if keeping the stock radio. You can also look at a processor or more affordably a good quality LOC. I put an MTX REq in my wife's Tacoma years ago and it still works very well.
― Thomas Paine
Old 06-15-2012, 04:06 PM   #7
_S7V7N_
_S7V7N_'s Avatar
Hookin up speakers will knock down the load. Unless it works diff on a headunit. I've never seen a headunit rated at 2 ohms.
Old 06-16-2012, 10:36 AM   #8
sqcomp
Roadrunner Jr.
sqcomp's Avatar
^ Agreed.
...but...but...whwatdyamean I can't hook up my HU into a 1/2 Ohm load? My friend did...and he made 237 dB from his 6x9s!
*barf*
― Thomas Paine
Old 06-16-2012, 05:51 PM   #9
yariSB86
yariSB86's Avatar
Thanks everyone for the input. I went to BestBuy today and picked up the following:
New HeadUnit
http://www.bestbuy.com/site/JVC+-+50...=1218447374174
Replacement front door speakers
http://www.bestbuy.com/site/Pioneer+...&skuId=3438938
I'm going to uninstall the two factory rear 5.25s and install those previously mentioned 6x9s. Where and how I'm going to mount these boxes is yet to be found hopefully when I remove all the trim Ill find a nice spot to secure them. I'm going to get started with removing all the trim and getting everything setup for tomorrow. Ill do a semi DIY and post pics tomorrow when everything is said and done. Wish me well m8s
Old 06-16-2012, 07:53 PM   #10
yariSB86
yariSB86's Avatar
6x9s are wired up and sound great. time for the replacement front door speakers and head unit!
Old 06-17-2012, 12:32 PM   #11
TOLMACH
Drives: soarer
^ Sorry man, I like neither the speakers that you bought nor the head unit (( I suspect the OEM stuff is way better ((
Old 06-17-2012, 12:40 PM   #12
_S7V7N_
_S7V7N_'s Avatar
Whenever you criticize somebody like that how about going into detail. If not you just come off as a troll.
YarisB. Keep doing your thing man. Everybody is going to have an opinion. Hopefully with reasons.
Old 06-17-2012, 12:55 PM   #13
TOLMACH
Drives: soarer
Am I criticizing anybody?
Stock front speakers are very good in terms of sq, nice flat response throughout the whole range, awesome low end response, high sensitivity (lightweight cone with small air gap). Overall very solid design with superb cast frame.
Same with stock headunit - nice SQ, decent internal amps
.. (sorry for bringing bad news)
Just my 0.02
Old 06-17-2012, 01:15 PM   #14
_S7V7N_
_S7V7N_'s Avatar
Just my 0.02
Now this opinion is somewhat more useful. You put the reason why you don't like the equipment.
Old 06-17-2012, 01:08 PM   #15
_S7V7N_
_S7V7N_'s Avatar
Yaris B. We usually ask for a bit of info.
Like :
Is this your first install.
Are you looking for Sound Quality or Just louder than stock.
A budget.
You also want to do some research online.
Keywords.
Ohms / Impedance / Load
RMS / Watts
Signal clipping / Distortion
You're not going to understand everything but it's basic knowledge.
So please do some research. From there we can build a foundation and help you a bit more.
So do some homework and report back on Monday !
Old 06-17-2012, 03:35 PM   #16
yariSB86
yariSB86's Avatar
i wanted to upgrade sq with a real tight budget. hence everything being on the cheaper side. its not awesome but its better than stock setup imo. everything installed just fine and sounds great. i feel that the new headunit does not supply enough power so i might invest in an amp, funds permitting. as for Tolmach, everyone is entitled to his/her opinion. yours just happened to be on the negative side. doesnt bother me, im still going to do what i want to do. thanks for all the advice S7V7N.
Old 06-17-2012, 11:34 PM   #17
TOLMACH
Drives: soarer
Man, you need not divide people into pos or neg here.. If you ask for advice or post something here, just be prepared to get the feedback. There are other ways to upgrade the stock system on a tight budget - I would probably just add couple decent tweeters to the front woofers and install 165 mm full range drivers in the rear stock locations. Again, this is just my way of doing this based on my experience.
Anyways, I am glad that you like the final result - this is what really matters.
Old 06-17-2012, 10:44 PM   #18
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I'll fall in line with what S7v7N is saying. Yeah, the equipment isn't the best in the world. We've got to start somewhere though.
I recall my first system. It was in a Geo Metro. A Coustic tape player, a small 25 x 4 Blaupunkt amplifier and a single MTX Blue Thunder subwoofer.
...those were the days...
Now it's travelling all over the country, going to CES, INAC and SBN and competing in sound quality competitions.
Point is, don't let anyone's opinion drag you down. Do what you need to do...and learn something. The latter is a must.
― Thomas Paine
No Sound Rear Speakers Help AutoXBot In Car Entertainment + Electronics (audio / video / alarm) 10 05-05-2011 03:41 AM
Need some experienced advice about speakers Nexus1155 In Car Entertainment + Electronics (audio / video / alarm) 0 06-28-2010 10:18 AM
Speakers for 2009 4DR LB AutoXBot In Car Entertainment + Electronics (audio / video / alarm) 5 05-02-2010 11:49 PM
Factory deck, new speakers sound no sound?? alan1828 DIY / Maintenance / Service 4 10-25-2009 03:36 PM
Matching up right speakers for 4DR Yaris.... ohms match up? ebowers83 In Car Entertainment + Electronics (audio / video / alarm) 7 09-13-2006 11:12 PM
