Old 02-28-2012, 12:48 AM   #1
Chocobo87
Drives: 2012 Blazing Blue Yaris(Auto)
Removal + painting?
Is there any videos or instructions with pictures of people removing the Toyota emblem from the front and the back?
I want to paint them flat black and then put them back on, but I don't know if they are just on with double sided 3m tape or something else.
Thanks!
Chocobo87 is offline   Reply With Quote
Old 02-28-2012, 02:55 AM   #2
SineWave
Drives: Gen3 Yaris ZR Manual
There's a couple of clips on the inside as well as the double sided tape. Remove the trim from the back door/hatch to get access.
SineWave is offline   Reply With Quote
Old 02-28-2012, 08:21 AM   #3
They changed the way they are mounted for the Gen3 model?
Prior years, the front emblem is four clips only. No tape. The rear emblem is tape only. No clips.
Old 09-28-2012, 10:37 PM   #4
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
The front emblem is deeper now and clips are a little different but it is still 4 clips on back
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 02-28-2012, 05:13 AM   #5
12 yaris
Drives: '12 Yaris LE Lagoon Blue Mica
Before you paint them you must sand and prep them,so the paint adheres to the emblems.
12 yaris is offline   Reply With Quote
Old 02-28-2012, 10:59 AM   #6
Chocobo87
Cool thanks for the tips! Keep them coming!
I will check it out later ^_^
Old 11-09-2012, 10:43 AM   #7
imike929
Drives: '13 Super White SE
Post some pics when you're done! There is a lot of talk of mods for 2012 but not too many pics. Thanks buddy
imike929 is offline   Reply With Quote
Old 02-28-2012, 11:37 AM   #8
CPALK719
CPALK719's Avatar
Drives: 2012 toyota yaris
there is new method that a friend of mine told me about, its called plasti dip. he just recently tryed it on his IS250 and loved the results. after spraying on you can just easily peel off the excess paint with no problem. i might be trying that myself soon.
2012 yaris L model
2014 wrangler unlimited sport
CPALK719 is offline   Reply With Quote
Old 09-28-2012, 07:50 PM   #9
nookandcrannycar
A member from Corpus Christi,Texas just did his rims in a sort of orange color. Another member in the U.K did his in black. Search plastidip and plasti dip with the search fuction. One of these hits includes a link to a YouTube video about the sublect with many similar videos listed on the right once you are onto that YouTube page. i'm sure your friend will clue you in re how to do it (if he hasn't already), but these other posts and venues will give you an idea what different aftermarket wheels look like with different dip color combinations and different car colors.
Old 09-26-2012, 11:09 PM   #10
libre homme
Drives: Toyota Vios 2009
nice tips
libre homme is offline   Reply With Quote
Old 09-26-2012, 11:36 PM   #11
Fidelio
EcoFriendly
Fidelio's Avatar
Drives: 2007 Vitz HB
also isopropyl alcohol is a great solution for cleaning the surface and emblem....
Fidelio is offline   Reply With Quote
Old 09-29-2012, 12:20 AM   #12
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Check the last two links on my signature... some good pointers in there!
Old 09-29-2012, 11:44 AM   #13
Shroomster
Shroomster's Avatar
Plus on the 2012 there is an extra piece of impact abs between the radiator and the front bumper at the top where the emblem is....
Old 09-29-2012, 10:52 PM   #14
jeeper5usa
jeeper5usa's Avatar
Drives: 2011 Toyota Yaris
Clips on 2011 rear emblem?
On my 2011 does the rear emblem have clips or no? What is easiest way to remove? Just pry it off?
I can see this is not going to go well.
jeeper5usa is offline   Reply With Quote
Old 09-30-2012, 11:16 AM   #15
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Everybody!
Search is your friend.
DIY: Debadge/Black out Emblems
A quick synopsis:
2006-2011:
Front: 4 plastic tabs hold it the the bumper
Back: 3M body tape holds it on and there are two alignment pegs
2012+:
Front: 4 slightly different plastic tabs hold it the the bumper
Old 11-09-2012, 10:33 AM   #16
treelowa
Drives: 2012 Yaris Trend
Use plastidip, don't even have to take them off the car :)
treelowa is offline   Reply With Quote
Removal of the Factory Integrated Source sqcomp In Car Entertainment + Electronics (audio / video / alarm) 7 08-24-2010 12:44 AM
Painting... naossoan Cosmetic Modifications (Exterior/Interior) 9 05-17-2009 11:25 PM
FS: Badge Painting Service (Two Tone available!) Corzy Items for Sale by private party 25 03-13-2009 11:55 AM
DIY: Painting Factory Brake Calipers redyaris DIY / Maintenance / Service 38 05-26-2007 08:47 AM
