Old 09-27-2012, 08:59 PM   #1
Killchain
Killchain's Avatar
Drives: '10 Yaris LB Polar White
Visor sticker removal
I haven't seen a post on this, maybe someone can help. Can these visor stickers/printed air bag warnings be removed? Any suggestions? I know the picture is bad.
Killchain is offline   Reply With Quote
Old 09-27-2012, 09:47 PM   #2
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Acetone. And it'll take forever. I only got a little bit off of my passenger side one and gave up.
Hate those warning stickers though!
From a PM convo I had with someone about the topic:
The first one I used the 4 to 1 water/acetone mixture, but had to let it sit for several minutes in order for it to bubble up off the surface. The second one I used straight acetone. Let it sit for a minute and wiped it off. You will still need to put some elbow grease behind it to get it off though. Leaving it on too long will eventually make the plastic tear as you wipe it so not a good idea to walk away from it but it's a lot quicker than the 4 to 1 mix. There will still be residual spots left over possibly. After you have wiped off the first attempt and cleaned it with water very well, just hand rub the leftovers with a cloth and acetone. The stickers they used were vinyl so it makes it very hard for use to remove them these days. Good luck and let me know how it works out for you. Be careful with the acetone too =)
Old 09-27-2012, 11:20 PM   #3
Killchain
Killchain's Avatar
Well then, I kinda guessed something like that of removing them. What would it do. I appreciate the replies. Thanks, it was a thought of some kind of mod.
Old 09-27-2012, 10:20 PM   #4
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
I hate those too .been looking into having them wrapped up it the same material as the headliner , did that on a couple of my other rides .
Old 09-28-2012, 10:32 AM   #5
matthewai
matthewai's Avatar
Drives: it is kinda stock
on my old car i painted them a wrap might be cool too but heres what i did for a while on the yarii
Old 09-28-2012, 10:39 AM   #6
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Replace them with this
http://www.decalpro.ca/catalog/fat%20chicks%20bike.jpg
Removal of the Factory Integrated Source sqcomp In Car Entertainment + Electronics (audio / video / alarm) 7 08-24-2010 12:44 AM
Paintless dent removal? schleppy New England 1 05-31-2010 06:04 AM
Paintless Dent Removal - Dent Magician Chupacabra General Yaris / Vitz Discussion 3 01-27-2009 10:07 PM
Weight Savings - Removal, Reduction, Reminder.... TRD_Yaris Performance Modifications 17 08-12-2006 02:07 PM
