Old 11-15-2012, 11:21 AM   #1
2o6
Drives: 2007 Liftback
Sedan owners - anyone install the S lip?
Anyone install this lip? How did it go? It seems straightforward, just a couple tabs on either side, and a few holes underneath where the lip attaches to the bumper.....but then there's these weird tabs that stick out from the lip and don't attach to anything.
I have instructions, but they're all in Japanese....
2o6 is offline   Reply With Quote
Old 11-15-2012, 11:28 AM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
take a pic of the whole lip and post Japanese instructions.
Old 11-15-2012, 11:38 AM   #3
Based on my experience with OEM lips on the HB, those 'weird tabs' would slip into slots that are cut in the OEM bumper facia, which do not exist on your car.
There may be markings on the back side of the bumper facia which indicates where the slots need to be made.
Old 11-15-2012, 11:45 AM   #4
2o6
But the illustrations show that I guess I need to drill into my bumper.....
Put my thinking cap on, and it shows that I need to drill holes in the bumper, then pull the tabs through the other side.
Old 11-15-2012, 12:16 PM   #5
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Nice when did you get that?
For the s lip on sedan you dont need to cut the bumper if you don't want. The tabs on the bottom as well you will see do not line up exactly to the stock mount points on your sedan.
To protect resale and make the job a whole ton easier I would just drill through the lip and make my own mounts and just secure with some screws underneath.
Because ours came as Base and not S all of those cutouts and mounts were ignored I found this out when I tried mounting mine.
Old 11-15-2012, 12:31 PM   #6
2o6
Mine actually is an S model, whoever fixed the car cheaped out and made some pretty ignorant shortcuts to save a few bucks. Part of me wants to cut the tabs out and double sided tape it, another part of me wants to let my bodyman figure it out; he'll be fixing it up anyways.
Old 11-15-2012, 12:38 PM   #7
1.5
Form>Function
1.5's Avatar
O true then your bottom mounts might have been messed up too. I would just shave the tabs and secure the lip via screws in the bottom it would be fast and easy and if you ever take the lip off there are no holes.
Your call
Old 11-15-2012, 12:51 PM   #8
2o6
I mean, it should be fine just by the bottom, right? The holes in the wheel wells are there, as are the ones on the bottom. Just the ones in the bumper aren't there.
Old 11-15-2012, 02:24 PM   #9
1.5
Form>Function
1.5's Avatar
Yeah absolutely the bottom/side mountings will be more than strong enough to hold the lip on.
Old 11-16-2012, 04:10 PM   #10
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I can tell you that the S package causes major headaches if/when you want to remove it. From what I can tell it is a major eff around to remove it without damaging it and making it usable again anyway. At least for someone with little patience.
Old 11-16-2012, 04:22 PM   #11
1.5
Form>Function
1.5's Avatar
That's why I advise him against cutting bumpers and such. Screwing through bottom should make it just as simple to remove.
Old 11-16-2012, 07:56 PM   #12
2o6
I will likely cut the tabs, I'll show my bodyman soon and see what he thinks.
Sedan Front Speaker Install Kaotic Lazagna In Car Entertainment + Electronics (audio / video / alarm) 5 07-09-2013 10:05 AM
Sedan K Sport Coilover Install **PICS** lkev Wheels, Tires and Suspension Forum sponsored by The Tire Rack 40 08-26-2011 03:12 PM
Lip kit for 2009 yaris sedan (Canada) ???? packetrace Cosmetic Modifications (Exterior/Interior) 3 09-24-2010 10:51 PM
Sedan S lip on hatch drell42 Cosmetic Modifications (Exterior/Interior) 18 05-31-2006 11:02 AM
