Old 01-11-2013, 12:21 AM   #1
Hershey
Denied waterpump replacement
by service center . Told has to be fresh coolant before they'll replace it . Guess have to wait until it fails and stranded on the road . Showed these pics of the coolant drops and the spray under the hood to service manager and said it's not enough proof . Did a 100+ round trip for nothing .
Old 01-11-2013, 12:33 AM   #2
Hershey
All levels cold on next day .
Old 01-11-2013, 01:10 AM   #3
Hershey
spray ...
Old 01-11-2013, 08:54 AM   #4
bronsin
bronsin's Avatar
Holy crap! Im sure this is not what Toyota Customer relations wants to have happen!
Old 01-11-2013, 10:54 AM   #5
Hershey
That's part of reason why we traded in the 2010 3 door for a '11 FIT . Hate to say it , but no more TOYOTAs for us . A shame , have had Toyotas since the late 80s' .
Old 01-11-2013, 10:47 AM   #6
Hershey
It's now closer to the LOW mark . Have a case number and that's of no help . Not sure what path to take . We have the Platinum warranty , what good is that if no one wants to touch it . First time I called them and asked if they could top it off . The person said they couldn't and didn't want to be liable if something happened . Also said it sounded like a waterpump issue and had one in stock . No winning .
Old 01-11-2013, 11:31 AM   #7
CoryM
Drives: 2009 5-door, 5-speed
No manufacturer will replace something that is "weeping". Weeping is moisture, film, evidence of leak but dry. It has to be "leaking" which is a current drip. It sucks, it's stupid, but that's how they all do it. I would suggest next time make damn sure it is wet with coolant at the weep-hole when you bring it to them.... even if you need to help it out a little.
Old 01-11-2013, 01:09 PM   #8
Hershey
" I would suggest next time make damn sure it is wet with coolant at the weep-hole when you bring it to them.... even if you need to help it out a little. "
Don't forget this is 50+ miles away .
Old 01-12-2013, 01:36 AM   #9
nookandcrannycar
How far away is the next closest dealership?
Old 01-11-2013, 11:38 AM   #10
Hershey
Took these a few minutes ago of cold coolant level . You can see previous cold levels where marked with a black sharpie . Going , going , ....
Old 01-11-2013, 02:58 PM   #11
Klink10
Klink10's Avatar
That's to bad. I know it's not the issue but I would just go ahead and replace it myself. You know the pump is failing. Toyota wants to be a dick about it so just do it for piece of mind.
Old 01-11-2013, 04:46 PM   #12
bronsin
bronsin's Avatar
I had coolant spray dried on the underside of my hood for six months before I brought the car into Toyota for replacement under warranty.
They replaced it without drama.
I had monitored the coolant level and there was little or no drop in the level at all. Im familiar with what typically happens when water pumps leak. In a few hundred miles they suddenly let go in a big way. That didnt happen with mine.
But the dealer changed it out anyway.
What causes this famous Yaris water pump issue I cant fathom. It didnt happen with the ECHO which uses the same engine. Or nearly the same. Its also apparently not the bearing going bad which causes catastrophic loss of fluid. Which doesnt seem to happen in this case.
Life is a crap shoot I guess...
Old 01-11-2013, 04:53 PM   #13
bronsin
bronsin's Avatar
I think though if it were me I would pay to have the wp replaced rather than buy a new car.
Thats a losing financial proposition.
In the paast when I was young and lusty I would do it myself.
Then maybe I would have figired this whole waterpump thing out and could give better advice...
Old 01-11-2013, 05:10 PM   #14
Hershey
Maybe when its water breaks we'll be able to get a police escort to the nearest Toyota dealer .
Old 01-11-2013, 05:11 PM   #15
Hershey
Why is it the service center would be concerned if they topped off the coolant ?
Old 01-11-2013, 07:00 PM   #16
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Is this the same dealer that fixed your oil leak?
Old 01-12-2013, 10:20 AM   #17
Hershey
No , dealer the car was bought at . There was a customer before me with a IQ and he said all kinds of profanity . He also called someone at the service desk a d*ck and was tired of getting the run around . When seeing that I knew it was less likely to get done .
Old 01-16-2013, 04:06 PM   #18
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
You might want to maintain required coolant levels to the best of your ability until a new waterpump can be installed, that picture of the spray mark makes me think if the coolant is coming out that fast i'd probably not drive the car as you could possibly run out of coolant entirely in a few miles.,
i'll presume with that amount of coolant loss that its spraying from the waterpump gasket that theres a large puddle of coolant under the car if parked for a while?..
Have Yaris will travel..
DIY waterpump RnR kou DIY / Maintenance / Service 86 03-05-2016 01:15 AM
OEM roof rack mounting rubber pad replacement Yai Cosmetic Modifications (Exterior/Interior) 3 12-22-2012 12:01 PM
Shock and Struts Replacement... New Tires Blowtorch DIY / Maintenance / Service 3 07-25-2012 12:44 PM
Single Tire Replacement - Using Pressure Sensor? 1stOne Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-13-2010 10:25 AM
