Old 01-12-2009, 04:10 PM   #1
kou
Drives: 08 lb
Exclamation DIY waterpump RnR
this was from before the hack just thought i would put it up again.
1.let the car cool down.
2.disconnect battery.
3.disconnect plug and wire from alternator,lossen two bolts on alternator so you can remove belt.
4.remove 10mm bolt from bracket holding ac hose and slide bracket back.
5.remove two bolts from alternator and take it out of the car.
6.remove waterpump pulley three 10mm bolts and remove pulley from car.
7.remove the bolts from the waterpump.
8.get a jack with a some wood to support the motor as you will need to remove the bolts from the side mount and drop the motor to remove the waterpump from the car.
9.put new waterpump on and do all this in reverse.
10.fill up coolant.
Old 01-12-2009, 07:03 PM   #2
CB900F2
Drives: 08 Sedan
Great post... How many miles/km on the car when the pump went?
CB900F2 is offline   Reply With Quote
Old 01-12-2009, 09:51 PM   #3
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
On Scionlife I have read about quite a few water pumps failing early. Same motor, same pump? Probably just a freak thing...
Edit- Well what do you know, 59,000 miles and my pump has some crust below the weep hole. These water pump failures seem to getting more and more common.
Old 01-12-2009, 11:27 PM   #4
kou
Drives: 08 lb
only 15,000 miles but i think it was my fault for tighetening the belt to much when installing NST pulley set.
Old 01-24-2009, 03:05 AM   #5
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
You have coolant all over the place. I just took my hood off because I was fiddling around with something and sure enough I have coolant on the under side of the hood. I have nowhere the amount you did and there was none on the pulley or in the vicinity. Either way the bitch is being changed out next week.
Ever blown out an R-200 diff god know's I have
ztrack157 is offline   Reply With Quote
Old 01-24-2009, 07:32 AM   #6
CB900F2
Drives: 08 Sedan
ztrack.. Did you also install a NST pulley and possibly over tighten the pulley belt?
Old 01-24-2009, 12:33 PM   #7
PetersRedYaris
What's the deal with water pumps failing on NST pulley equiped engines? I don't think mine was affected by the pulley as the WP bearing noise started just a few miles post the NST installation and the antifreeze "crust" looked like it had been there awhile, though I didn't see it when installing the pulley.
My belts are definitely not to tight as I like them on the loose side. So long as they don't squeel, they're tight enough.
Old 01-24-2009, 02:14 PM   #8
kou
Drives: 08 lb
i think mine was bad before the nst pulleys.maybe just the way the belt is tensioned from the factory.
Old 01-24-2009, 02:46 PM   #9
ztrack157
ztrack157's Avatar
I have NST as well. And in the last 2,000 miles I heard a noise I knew shouldn't be coming from the engine bay. It was the water pump. I don't know what is considered to tight I can still wiggle the belt. And I had thought it was to tight so i loosened it slightly and then spun the belt so it wasn't to tight after installation.
Old 01-24-2009, 02:48 PM   #10
auxmike
auxmike's Avatar
THe pump's not covered by the warr. guys?
Why did'nt you just let the dealer shoulder the labor/cost?
Don't you get 5/60,000 on the drivetrain???
Old 01-24-2009, 02:49 PM   #11
ztrack157
ztrack157's Avatar
Yes we have that but with NSt they can say we over tightened the belt. Thus no warranty.
Old 01-24-2009, 03:26 PM   #12
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
this problem isn't specific to nst equipped cars so don't start assuming its gonna happen to you if you have or are gonna buy. my buddy who's a toyota mechanic says water pumps and yari are starting to become a regular thing at his shop.....
Old 01-24-2009, 03:32 PM   #13
nemelek
DWEED
nemelek's Avatar
How much does a water pump cost? Did you get from Toyota or some place else like Auto Zone or NAPA?
Old 01-24-2009, 04:15 PM   #14
auxmike
auxmike's Avatar
Wonderful.
Did he give you any idea on about what milage the pumps go?
That's unacceptable, especially for a make like Toyota, supposedly "the best".
Thanks for the heads up, BTW.
Now I gotta start watching a waterpump on a brand freakin' new car........
Old 01-24-2009, 04:21 PM   #15
auxmike
auxmike's Avatar
The Genuine dealer water pump MSRP is about $100USD. I've seen it OEM on the net for $75USD.
Pump includes parts #8 & #9 in the sketch below.
Hope this helps.....
Old 01-24-2009, 04:26 PM   #16
PetersRedYaris
I agree, it's just kinda funny that most of us have an NST pulley installed.
Old 01-24-2009, 04:28 PM   #17
PetersRedYaris
Go to Sparks Toyota-
http://trdsparks.com/index.php
$53 for the OEM pump and gasket...
Old 01-24-2009, 04:31 PM   #18
auxmike
auxmike's Avatar
Are you guys running the TRD rad caps too?
Perhaps too much pressure for the pumps seals?
Hope the Yaris does'nt turn out to be a Japanese Yugo.....
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
DIY Requests. TinyGiant DIY / Maintenance / Service 13 10-29-2008 10:39 AM
